3230 keypad not working, checked the UI board with other set its working proper also changed keypad IC but the problem is same. Pls give solution . Thanks in advance. |
6120c LCD no light any solution? |
6300 keyboard not working at all STRANGE PROBLEM : 6300, only on/of works,KEYBOARD IC chaged z2400 ic, but no success, tryed flashing, etc, but always same, no one key works at all, i hope is not rap !!!!!!!! ANY HELP ? CONTACT ME ON PM SKKEPTIK |
verry verry thx a lot............... |
i have keypad problem in nokia 1650 please help me with diagram/picture |
So Plz Use Thanks Button If Ur Aim Is To Increase The Number Of Posts Then, Carry On ............................ |
2760 no light on main lcd... the small lcd and keyboard is OK. But main lcd haven't light. I try with new lcd but nothing.. pls help! |
mmc solution Quote:
change mmc black ic............ problem is solved................. |
please help me for nokia 2600 classic 'charger not supported'....than*** |
1650 [quote=billal930;3268183]1650 Localmode . plz help |
nokia 6600 note open gallery hellp me |
flash the phone with good pm file if not solved then try to rehot bt module or change it with new one , you can also flash the set using ufs by selecting skip bt flashing but in this method you are not able to use bluetoothpost result |
hai i want 1650 localmode sol.picture.please help me |
