Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
01-28-2010, 12:25 | #346 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Edinburgh, SCOTLAND
Member: 297431 Status: Offline Thanks Meter: 7 | i can get it fixed again but when it gets fixed if i try unlocking it again will it die . wb Auto1 |
01-28-2010, 14:30 | #348 (permalink) |
Junior Member Join Date: Jan 2008
Member: 690412 Status: Offline Thanks Meter: 1 | hi my friends i have n81 the lcd become blank i change the lcd and the flat cable but still the same ................. and i have 3110 fall in water , i have cleaned very well , now it works but there is a problem that i charge the battery , it works for nearly 4 hours and becomes empty , i change all the ics for charging but still the same can somebody help me please ...................... |
01-30-2010, 05:45 | #350 (permalink) |
Junior Member Join Date: Aug 2006
Member: 334020 Status: Offline Thanks Meter: 4 | master,pls help me !!! my e52 charge 1 day still cant full,when i unplug the charger.the hp will show me "battery low"then auto off...!i try to change power ic (4376051)but problem same) can help me solve this problem,thanks... |
01-30-2010, 09:58 | #356 (permalink) |
Member: 690412 Status: Offline Thanks Meter: 1 | i have n81 the lcd become blank i have change the lcd and the flat cable and still the same some body help me please........ also i have e65 the same problem some one can help ...thank you |
01-30-2010, 10:55 | #358 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1222718 Status: Offline Thanks Meter: 0 | 1208 charging promlem solution are - first check the key board LED, 2. check the VBAT voltege 3.7 in Boost coil & capacitor, 3. check lighting voltage in LCD connectot pin no 10 12.5 if not then change the light IC. |
post all nokia software problem here, i will try to solved. | shahinahmed007 | Nokia Base Band 5 ( BB-5 ) | 145 | 11-04-2016 15:50 |
All Nokia Software Problem Solved .............. | GsmUniversal | Nokia Hardware & Hardware Repair | 19 | 02-26-2011 13:18 |
