Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
10-12-2005, 00:31 | #271 (permalink) |
Freak Poster Join Date: Mar 2005 Location: tunisia / belgium Age: 46
Member: 123433 Status: Offline Thanks Meter: 14 | Quote: Originally Posted by gsm st hi all 2300 pec. 100% work but do.t charging i ve cheng r100 problem is sem thanks hi friend your problem is uem chip..charging will be ok |
10-12-2005, 00:37 | #272 (permalink) |
Member: 123433 Status: Offline Thanks Meter: 14 | 6100.7210.6610.charging problam 6610.6100.7210. carging simbal ok but not charging *** battery ok L100 v100 c100 ok wen pulag chargar battery contct 1volt not 4.5volt pleese Help Me thank you By rahmanp |
10-12-2005, 00:40 | #273 (permalink) | |
Member: 123433 Status: Offline Thanks Meter: 14 | hi Quote:
10-15-2005, 21:48 | #280 (permalink) | |
No Life Poster Join Date: Aug 2005 Age: 46
Member: 166746 Status: Offline Thanks Meter: 86 | .. Quote:
and take your multimeter anc check if the lines all are making contact. | |
10-17-2005, 00:07 | #284 (permalink) | |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | Quote:
You want to show NAND RAM ! On the other side of PCB. But you are showing Bluetooth module removed ????? Just to inform others ! Regards | |
10-17-2005, 15:50 | #285 (permalink) |
Member: 123433 Status: Offline Thanks Meter: 14 | to moderateure thanks to tell y have some problemes with up load picture rar and pdf , hy do not acceptmy fils and y do not undersandt why |
all nokia hardware solution | Harkishan singh | Nokia Hardware & Hardware Repair | 4 | 04-23-2010 12:53 |
All Nokia Hardware Solution In One Player | morshed | Nokia Hardware & Hardware Repair | 0 | 06-17-2008 17:37 |
All nokia Hardware Solution | najafi | Nokia Hardware & Hardware Repair | 9 | 04-25-2007 06:30 |
all nokia hardware solution with pictures | sainianil | Nokia Hardware & Hardware Repair | 16 | 12-09-2006 12:35 |
