Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
05-24-2005, 23:48 | #469 (permalink) | |
Cheater -Don't Deal with him- Join Date: Mar 2003 Location: ITALY
Member: 23994 Status: Offline Thanks Meter: 43 | Quote:
www.decoder.wz.cz look out for the thread on 'LEARNING THRU PICTURE' | |
05-25-2005, 18:42 | #472 (permalink) |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | i have a 8210 that only works on 1800mhz 100% in 900 i can see the full signal bar. but wehn i make a call, the computer monitor won't show the fluctuating signal. I already change the Antenna switch, PA, COBBA, CCONT, HAGAR, CPU AND FLASH IC rehoted (GLUED). but i still don't see the fluctuate signal in the monitor. Help |
05-26-2005, 11:41 | #473 (permalink) |
Freak Poster Join Date: May 2005 Age: 48
Member: 142994 Status: Offline Thanks Meter: 66 | 3220 network i've 3220..i was damaged by water...that time it was dead but after a day its starting..well but problem is INSERT SIM CARD..then i changed SIM IC..its worked..but no signal..but its giving signals with Reliance Smart Provider..i think 800 Mhtz..but no any signals with Airtel Provider 1800 Mhtz..but after few day again same problem INSERT SIM CARD..again i changed that little glass IC..its worked again..but..no any network..with both of frequincies...but its searching well all networks by manually...so..can u gimme suitable solution....do u think shud i flash it..n one thing more..when i opened gallery's contents..its rebooting itself..pls suggest me..what shud i do |
05-26-2005, 11:50 | #474 (permalink) |
Member: 142994 Status: Offline Thanks Meter: 66 | 3220 network -------------------------------------------------------------------------------- i've 3220..i was damaged by water...that time it was dead but after a day its starting..well but problem is INSERT SIM CARD..then i changed SIM IC..its worked..but no signal..but its giving signals with Reliance Smart Provider..i think 800 Mhtz..but no any signals with Airtel Provider 1800 Mhtz..but after few day again same problem INSERT SIM CARD..again i changed that little glass IC..its worked again..but..no any network..with both of frequincies...but its searching well all networks by manually...so..can u gimme suitable solution....do u think shud i flash it..n one thing more..when i opened gallery's contents..its rebooting itself..pls suggest me..what shud i do |
05-28-2005, 00:18 | #475 (permalink) | |
Insane Poster Join Date: Apr 2004 Location: Lagos,Nigeria Age: 44
Member: 62953 Status: Offline Thanks Meter: 6 | Quote:
05-29-2005, 04:17 | #477 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: NEW DELHI, INDIA Age: 50
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | Quote:
05-29-2005, 04:18 | #478 (permalink) | |
05-29-2005, 07:50 | #479 (permalink) | |
Member: 142994 Status: Offline Thanks Meter: 66 | 3220 fully netwowork gone Quote:
05-29-2005, 09:55 | #480 (permalink) |
Junior Member Join Date: May 2005 Age: 41
Member: 146018 Status: Offline Thanks Meter: 0 | guys does flash ic can cause no signal??? i have N8210 no signal when pwer on i tried to reflow the hagar and cobba change the antenna switch and reworks on duplexer and filter still no signal and also line from audio are cut off i mean u cant here the person from other line which ic should i must replace |
1220 NO signal solutions | mrfixit | Various CDMA/TDMA Cell Phones | 2 | 03-16-2017 04:26 |
Nokia 1600 no signal solution required | azam_gsm1 | Nokia Hardware & Hardware Repair | 9 | 02-23-2009 11:03 |
3100 No signal solution | irfaN_vu | Nokia Hardware & Hardware Repair | 31 | 05-22-2008 03:54 |
For new beginners. here Nokia code's | pazeth™ | Nokia Hardware & Hardware Repair | 0 | 06-26-2005 15:20 |
lg 8110 no signal solution | ihsanali | LG | 5 | 03-03-2005 11:51 |
