Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
07-25-2005, 09:31 | #541 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 42
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | hi but still no network even no name of any network and notjing shows any name of service provider on screen :::::)))) |
07-25-2005, 13:12 | #542 (permalink) |
Junior Member Join Date: Feb 2005 Age: 54
Member: 118292 Status: Offline Thanks Meter: 2 | Nokia 3200 Connection error Hi, My daughters Nokia 3200 startet having connection problems. When turning on the phone it gets the signal (most of the time), but when trying to make a call it suddenly says "error on connection" and the it has lost the signal. Can it be the antenna? regards nimmer PS. After a while it seems that it gets the signal back - and no it's not in an area with bad signals. Last edited by nimmer; 07-25-2005 at 13:24. |
07-31-2005, 12:14 | #544 (permalink) | |
Junior Member Join Date: Mar 2005 Age: 45
Member: 129826 Status: Offline Thanks Meter: 0 | Quote:
08-08-2005, 12:01 | #547 (permalink) | |
Junior Member Join Date: Jun 2005 Location: Pakistan Age: 40
Member: 154830 Status: Offline Thanks Meter: 2 | Fadig(FaHaD Ali) Quote:
or What [email protected] | |
08-09-2005, 19:36 | #548 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 46
Member: 166746 Status: Offline Thanks Meter: 86 | Hi there, I read through all the threads but cannot find the answer im looking for, Im jsut starting with smd repairs, I recently got a SMD hot air station, and I need some pointers / tips using it... I can change power on /off and 3310's and charging blocks t190 etc.. withour hassle, Im having trouble removing PA. DO i heat it from the top on the PA itself or heat it from the bottom through the PCB where theres holes??? 2ndly . I removed the haggar from the dead 3310 board, after i removed it the small spots of soldier seemed asif they have touched each other in the middle , if i replace will the board function?? if nto how do i change the haggar withouht messing tghe balls of soldier up . iM using a hot air ****er and a tweezer... pls assist. thanks |
08-09-2005, 20:35 | #549 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Nokia 3310 no network in manual searching after60 to 70 sec.,an****a switch,hager already changed, keypad tone is ok I think cobba is ok,crystall changed nothing happen. any member teach me about hardware testpoint with pics. |
08-09-2005, 20:46 | #551 (permalink) | |
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
08-10-2005, 11:44 | #552 (permalink) | |
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | 1100 no network Quote:
08-14-2005, 06:02 | #553 (permalink) | |
1220 NO signal solutions | mrfixit | Various CDMA/TDMA Cell Phones | 2 | 03-16-2017 04:26 |
Nokia 1600 no signal solution required | azam_gsm1 | Nokia Hardware & Hardware Repair | 9 | 02-23-2009 11:03 |
3100 No signal solution | irfaN_vu | Nokia Hardware & Hardware Repair | 31 | 05-22-2008 03:54 |
For new beginners. here Nokia code's | pazeth™ | Nokia Hardware & Hardware Repair | 0 | 06-26-2005 15:20 |
lg 8110 no signal solution | ihsanali | LG | 5 | 03-03-2005 11:51 |
