Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
04-29-2009, 18:23 | #993 (permalink) |
Freak Poster Join Date: Feb 2009 Location: INDIA
Member: 963505 Status: Offline Thanks Meter: 50 | tweety06;4383119]my nokia 6600 keypad is defect.4,6,# is working.please help[ BRO FIST CHECK KEY PAD 2- CHECK KEY PAD CONNECTER 3- CHENGE KEY PAD IC 110% SOLVE ENJOY |
04-29-2009, 18:29 | #994 (permalink) |
Member: 963505 Status: Offline Thanks Meter: 50 | wolf_wood;4362778]can anyone help me with my 6600 cant boot mobile......i can complete flash .....then after flashing Failed aborting......i already heated 4 flash ic and upp......did i miss something?......[/ U CHENGE FLASH FILE VERTION & REBALL RAM |
05-05-2009, 09:05 | #997 (permalink) |
Junior Member Join Date: Mar 2009
Member: 998753 Status: Offline Thanks Meter: 1 | 6600 no tone, buzzer ok i have a nokia 6600 but its buzzer doesn't function after being drop, im still hesitant to reheat uem for fear of killing the fone.. any ideas? thank you very much! |
06-23-2009, 08:17 | #1001 (permalink) | |
Freak Poster Join Date: Dec 2006
Member: 408989 Status: Offline Thanks Meter: 21 | Quote:
1. Replace with a good keyboard (damn cheap for nowaday, cost around USD$2). 2. Check the UI connector X140 (PCB board keyboard connector) pins. 3. Rehot or replace keypad IC (check schematic if you don't know). You can download nokia schematics from here - http://www.shrak-mobile.com/eng/schem_nokia.html 4. If non of them above could solve your problem then you are so lucky that you have to deal with CPU. From the question you asked, you're quite a newbie for me. So I think the first step may be your only choice. Read through schematic, it would give you a lot of help. | |
06-23-2009, 09:10 | #1002 (permalink) | |
1. Have you checked your buzzer ? 2. Have you checked your PCB board buzzer pins & capacitors, resistors, etc which are near buzzer pins ? Are they broken ? Missing ? Dropped off ? Espeacially L359 & L360. 3. Have you checked your buzzer IC ? N330 ? 4. Now only comes to UEM. If you're facing a glued UEM then you have to apply more heat & more flux to remove it but not too hot ! It could damage your PCB UEM's legs. You should check your phones start from minor problem. That's what a technician should follow. Many things could be fixed easily, you just have to keep yourself clear enough to analyse the problems. Sometimes, it's not as complicate as you thought. Just don't MASS OUT the problems ! | |
The Following User Says Thank You to lokkinho For This Useful Post: |
06-23-2009, 09:25 | #1003 (permalink) | |
Remove the bluetooth module(N430) metal cap, and you will see a little tiny flash chip that looks like 3310 flash chip which got a model no. - M28R400CB. That's what we called bluetooth flash ic. What you have to do is replace it or reball it. Reheat - not recommended. Problem not solved, replace UEM. | |
07-17-2009, 11:20 | #1004 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1049906 Status: Offline Thanks Meter: 1 | 6600 white screen i have a 6600, and it has a white screen, but i can type on the number for its balance inquiry, what should i do to fix it, without using a computer like typing any codes that can fix the problem. it u have any solution like white screen in n series cellphone pls. tell me, like the n70 or n95. thanks. with out using a computer. |
The Following User Says Thank You to gannovember For This Useful Post: |
07-20-2009, 20:38 | #1005 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1079008 Status: Offline Thanks Meter: 0 | hi my nokia 6670 does want to switch on, every time i switch it on it gives me a white blank screen. at first it use to show " return to vendor, software re-installation". how can i fix this problem? any ideas??? |
Motorola W220 Display Problem Solved Here | Kanwalgee | Infinity-Box | 41 | 04-19-2013 18:26 |
et related problem solved here | gurukripa1982 | ET-BoX | 31 | 07-07-2010 03:50 |
problem solve here!!! | utol_kiko13 | Nokia Hardware & Hardware Repair | 34 | 04-23-2009 04:55 |
7250i problems solved here | gsmindia | Nokia Digital Core Technology 4 ( DCT-4 ) | 38 | 08-31-2007 04:06 |
