Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 08-20-2007, 20:42   #3826 (permalink)
Member: 438710
Originally Posted by velson View Post
is it your phone still can make call ?? if can you need to change your display ic , if cannot you need to do full flash for the phone .. good luck !
dear friend,
before flashing your N70 try this also
remove your battery and mem.card
put it back the battery
press and hold three buttens given below
  1. dial 3 button
  2. *(star) button
  3. call Button(Green)
then power on
dont release any button untill you see a formatt command.
let me know thw updates
Old 08-20-2007, 21:16   #3827 (permalink)
Member: 438710
Talking
Originally Posted by gitesh View Post
i have searched all the forum but i got no answer of my question. i have a cd player its motherboard was not working so i changed it . after changing it my front panel on which all the buttons are mounted not working . for solving this problem i have heard that rom ic should be programmed . so i want to know how to write a rom ic and with the help of what hardware and software. i am eager to know. if you could help me i will be thankful to you. waiting for your replayl
Dear Friend,
you are in wronk place
here the discussion only about mobile phone
Old 08-23-2007, 17:32   #3828 (permalink)
Member: 333476
hi bro i had a nokia 6070 keypad malfunction no.3,6,9 need also diagrams thanks
Old 08-24-2007, 13:05   #3829 (permalink)
Member: 524839
Originally Posted by nolyboy View Post
hey guys post your problem here ill try to help
hi niren my n6630 is a white display im not create solution
Old 08-25-2007, 06:01   #3830 (permalink)
Member: 266060
Thanks Meter: 7
sorry dont know............................................
Old 08-26-2007, 08:54   #3831 (permalink)
Member: 573737
hi i have vibration problem with nokia 6310i .. vibration doesnt works with my phone, can any one help me out????
Old 08-26-2007, 10:48   #3832 (permalink)
Member: 410061
Cool nokia n70 white screen
i have nokia n70 with me i change the lcd and flash it but still not display.
please" help me find solution to this problem.
thanks mike
Old 08-26-2007, 11:45   #3833 (permalink)
Member: 516585
rm-166
helf me please needed firmware rm166
Old 08-27-2007, 03:15   #3834 (permalink)
Member: 573337
Low signal
I have a nokia 6210. It has started to have a very low signal.
I have read some posts and it seems it might be the ccont, cobba, aerial switch, hagar.
WHERE are these parts? Where is a diagram that shows me where the ccont, cobba, switch, hagar are?
The service manuals have scematics and part numbers. Neither tell me where the ccont, coba, switch, hagar actually are!!!?
please help!
Old 08-27-2007, 04:29   #3835 (permalink)
now_mobiles's Avatar
Member: 233492
Thanks Meter: 93
How to reformat Nokia 7700 and 7710?
In case of serious problems with your Nokia 7700/7710 (if e.g. your phone doesn't start or it is very unstable) use the following method to reformat the device. Please, be aware that this function brings your phone back to a factory state, i.e. it removes all applications, files and data.
Disconnect the charger and remove the battery.
Wait for about ten seconds and insert the battery to start the device.
When you see the NOKIA welcome screen, immediately press and hold two lower keys on the left side (the [= key and the Menu key) and shortly after that press and hold the second key from the top on the right side on the phone.
Confirm that you want to format. Formatting will start.
Old 08-30-2007, 06:51   #3836 (permalink)
Member: 546348
6260 upkey,down key,left&right key not work please help
Old 08-30-2007, 09:18   #3837 (permalink)
Member: 575890
The mic of my nokia 5200 is not working whether it is call, audio record or video record... even if i use headset the mic still doesnt work, they cant hear me... is there anyway to fix this?? help me please...
Old 08-31-2007, 02:14   #3838 (permalink)
Member: 543306
sir any idea about n90 that auto restarts it cant also be connected by dku2 and fbus cable
Old 08-31-2007, 17:10   #3839 (permalink)
Member: 574067
nokia 6510
display problem of my 6510..on & off display
Old 08-31-2007, 17:12   #3840 (permalink)
Member: 574067
can you help my 6510 display problem? on & off lcd display
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair 2161 12-25-2023 05:54
Post me your BB5 problem here.. Ill try to help with Pict Rizal Arsyad Dini Nokia Hardware & Hardware Repair 13 10-05-2014 09:23
!!!!post Me Your Hardware Problem!!!! Ustad rajab.Com Nokia Hardware & Hardware Repair 32 01-18-2013 08:37
post me your all 6600 problem tommobil2005 Nokia Repair Guide and FAQ 459 01-17-2011 12:23
Page generated in 0.34188 seconds with 10 queries
