Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
07-11-2010, 17:11 | #7670 (permalink) |
Junior Member Join Date: Dec 2003 Location: Nederland Age: 53
Member: 45997 Status: Offline Thanks Meter: 0 | Codes not working on samsung s5230 Hi, I needed the unlockcodes for the samsung s5230 with imei: 35210404170964/7 Response was: flash: 67036021 unlock: 38049851 both of the codes don't work :-( system is frozen now. please help |
07-11-2010, 19:06 | #7671 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1343105 Status: Offline Sonork: soso Thanks Meter: 0 | Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device: Soft reset code *#7370# Hard reset code *#7780# If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95: + Turn off the mobile device. + Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3″ button. + While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details. |
07-12-2010, 14:02 | #7678 (permalink) |
Freak Poster Join Date: Apr 2009 Location: PAKISTAN , LAHORE Age: 42
Member: 1021182 Status: Offline Thanks Meter: 39 | I NEED KEY PAD JUMPERS FOR 6820a SET IS OK BUT UPER KEY PAD IS NOT WORKING ANY 1 HELP ME THEAR IS THE BOARD PICTHER THEAR IS DISASSEMBLY VIDEO http://www.mygsmtube.com/videos/106-...-assembly.html ABDULLAH81 |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
