Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
09-23-2011, 08:49 | #8416 (permalink) |
Junior Member Join Date: Sep 2011 Location: minnesota Age: 33
Member: 1660112 Status: Offline Thanks Meter: 0 | dapeng t5000 problems help plz |
09-27-2011, 11:00 | #8420 (permalink) |
Member: 1660112 Status: Offline Thanks Meter: 0 | forgot to add my phones info Dapeng t5000 duel sim by, Digital Mobile GSM850/GSM900/DCS1800/PCS1900 USING T-Mobile Sim Version- E728_HJY1WT5.01.0 Branch - 08B Build - BUILD_NO Serial# - E7280V11J1009130124 Build time - 2010/09/13:57 BB chip - MT6235, E04 DSP code - 2000.00.00 DSP patch - 1.0 MS board - EVEN35_08B_HW IMEI:1 - 358809025496441 IMEI: 2 -358809021275872 I found the firmware, now im just looking for some kind of directions on how to flash my dapeng T5000 back to factory settings so i can finally get my screen back to normal and not have it say insert sim and actually be able to use sim 1! please help i've been at this for almost a week now! also i need to know of a good application to add java and such back to the phone after and a good flashing app. thanks in advance |
09-28-2011, 08:34 | #8423 (permalink) |
Junior Member Join Date: Sep 2011 Location: philippines
Member: 1662865 Status: Offline Thanks Meter: 0 | please help. i tried to reformat my samsung sgh-a187 using full, but accidentally removed the battery. when i put back the battery and switch on only flashing at&t and not proceeding to open. only flashing. please help and thank you so much. im new here. |
09-28-2011, 08:42 | #8424 (permalink) |
09-28-2011, 12:32 | #8425 (permalink) |
Junior Member Join Date: Jun 2008
Member: 787818 Status: Offline Thanks Meter: 4 | 1ST BOOT : C0,07 [Rm-243] [2.2.0.2] CMT ASICID: 000000010000022600010006400C192101051103 EM 1 ID : 00000296 EM 2 ID : 00000B22 CMT PUBID : 1C700007D3A8005215BF5F15C21D0540487AD8D3 CMT MODE : 00 CMT HASH : 479C6DDE3942E12C429C1D6ADED80371 CMT ROMID : 4B9B75103E691FF8 CMT 1ST Boot OK Cannot Find KEYS CERT BAD BOOT ERR: CMT 2ND Boot File not Found IMAGE : rm243_07.20_prd_core.fpsx Process Failed, Repowering Mobile |
09-29-2011, 12:28 | #8426 (permalink) |
Insane Poster Join Date: Nov 2007
Member: 634458 Status: Offline Thanks Meter: 21 | bro healp me on nokia 5800 reastart solution i am flash latest ver 52.101.16 but after 15 mint mobile is reastart.. |
The Following User Says Thank You to swasti For This Useful Post: |
09-30-2011, 08:28 | #8427 (permalink) |
Member: 1664363 Status: Offline Thanks Meter: 0 | Nokia 6500s damgaed by nokia software updater Hi there, Just tried to update software for 6500s using nokia software updater and it froze in the middle of update. Phone is blank and will only turn on by removing battery and turning on again, but blank screen only. My computer installs drivers for it when plugged in by USB but nokia software updater does not recognise it. Tried reformatting by holding down green, *, 3 and pressing down on power button but nothing. Is there anything I can do to get this phone working again? Any help would be greatly appreciated Damien |
10-12-2011, 00:46 | #8428 (permalink) |
Junior Member Join Date: May 2011 Location: ghana
Member: 1581726 Status: Offline Sonork: usher3g Thanks Meter: 0 | Please i need help ,i have nokia 2700classic .it restat 3minis all the time,i have flash it ,but it repeat itself.what am i going to do,please heip? |
10-16-2011, 07:05 | #8430 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1170314 Status: Offline Thanks Meter: 8 | Phone type: RM-495 (Nokia 5130c-2) SW version: V 06.94 21-07-09 RM-495 (c) Nokia Imei plain: 35937103049379-7 Product code: 0591479 Battery voltage: 4489 mV, current: 58 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359371030493797 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BUT MY SET IS CONTACT SERVICE... wat can i do now????? |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
