Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
09-16-2008, 13:31 | #4982 (permalink) |
Freak Poster Join Date: Feb 2006 Location: INDIA
Member: 237007 Status: Offline Thanks Meter: 75 | My N70 Show White Display I make All Jumper But Same Condition .I check Info With JAF Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk07v25 01-09-05 RM-84 (c) Nokia. HW version: 6001 PCI version: RFIC version: 150a160e DSP version: rolf_05wk07v19e Retu version: 32 Tahvo version: 41 Production serial number: SVI452734 Product code: 0523737 Module code: Basic production code: 0522156 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 357093009041488 IMEI spare to net: 3A 75 90 03 90 40 41 08 IMEI SV to net: 33 75 90 03 90 40 41 08 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0523737 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V01 CNT Flash file: NONE APE Variant file: ? Done! Please Help How to solve this problem |
09-16-2008, 13:34 | #4983 (permalink) |
Junior Member Join Date: Jun 2008 Location: Pattukkottai
Member: 796124 Status: Offline Sonork: [email protected] Thanks Meter: 2 | 6680 charging complaint wat 2 do |
09-17-2008, 03:58 | #4985 (permalink) | |
Freak Poster Join Date: Oct 2006
Member: 374062 Status: Offline Thanks Meter: 8 | why no reply my frn pls reply soon reply i am keenly waiting 4 yr reply pls urgent d Quote:
09-17-2008, 06:56 | #4989 (permalink) |
Junior Member Join Date: Jun 2006 Location: rawalpindpakistan Age: 41
Member: 290315 Status: Offline Thanks Meter: 5 | hi 2 all i have nokia6600 problem is no gallarey open no camara wrok i do flash i do framet but set have still same problem plz try 2 salove my problem |
09-17-2008, 07:00 | #4990 (permalink) | |
No Life Poster Join Date: May 2006 Location: ..::INDIA::..
Member: 279604 Status: Offline Sonork: 100.1582858 Thanks Meter: 198 | Quote:
erease and flash,write good pm ,format unlock and repair bt if same problem try in hardware ... try to heat bluetooth ic (bt module) if same replace and cheak | |
09-17-2008, 07:26 | #4991 (permalink) |
Member: 290315 Status: Offline Thanks Meter: 5 | hi dear i have d500 set is on but no key wrok set is hang i fromet all the set after fromet set is wroking but now set is same problem plz tell me what i do now thanks |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
