Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
03-27-2009, 11:22 | #5974 (permalink) |
Junior Member Join Date: Mar 2009 Age: 43
Member: 997599 Status: Offline Thanks Meter: 0 | Hello nolyboy, 5310b RM-304. No power. Fails flashing with code D386 "The configuration response from the Phone informs about fail. The Programming Device copies the Phone response contents to the preceding FIASCO_GENERAL_INFO_IND message" All regulator voltages, clocks, and signals that we can check are present. Going to try and change Combo memory today. Any tips? |
03-27-2009, 12:18 | #5975 (permalink) |
Junior Member Join Date: Feb 2008
Member: 715254 Status: Offline Thanks Meter: 0 | 6610i contct sarvice palese help mi thise emele [email protected] |
03-28-2009, 02:03 | #5976 (permalink) | |
No Life Poster Join Date: Nov 2007
Member: 627228 Status: Offline Sonork: 100.1577983 Thanks Meter: 155 | Quote:
Frist try to write Good PM If not solve this you Problem try to heats you PCB B.R.,vali23_mm | |
03-28-2009, 17:53 | #5983 (permalink) |
Major Poster Join Date: Feb 2004 Location: MAROUA CAMEROUN Age: 59
Member: 52636 Status: Offline Thanks Meter: 5 | ZTE A35/A66/A68 NOR UNLUCK ODER MODEL PROBLEM THE ZOIN AND MOOV WITCH INFINITYBOX CELTEL MODEL IS OK NOPROBLEM TANK FOR HELP PLS HELP COM23 [VCP0] selected module v1.64 Device: ZTE-A66 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... next part... boot answer: 00 error: unknown bootcode answer: Release Power button now Boot Failed Finished, time used: 6 sec Remove/Install battery now ! |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
