Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
04-15-2010, 19:14 | #7426 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Bangladesh Age: 37
Member: 473746 Status: Offline Sonork: 100.1589354 Thanks Meter: 70 | Step 1. Proper clean ur LCD base, connector and main board. Step 2. Change ur mobile LCD. Step 3. Collect another mobile to compare and find problem. Step 4. Change any related LCD parts. Step 5. Change upgrade flashing software. Bestregard..................hmyeamin |
04-15-2010, 19:40 | #7428 (permalink) |
No Life Poster Join Date: Oct 2009 Location: kashmir Age: 34
Member: 1134507 Status: Offline Sonork: 100.1607956 Thanks Meter: 201 | when i falsh any set or ears any set my mx key show that ram perolim but usf3 solve this perolim no one set falsh plz bro help me plz on my id [email protected] im waiting ur reply plz help me |
04-16-2010, 07:36 | #7430 (permalink) |
Insane Poster Join Date: Jul 2009 Location: **********
Member: 1073029 Status: Offline Sonork: 100.1587016 Thanks Meter: 49 | I need help I have N72, which operateon only Waridtel (Pakistan) and automatically restart after some time. Log file is as under:- Phone Type: RM-180 (Nokia N72) SW Version: V 05wk07v47 30-01-07 RM-180 (c) Nokia. Imei plain: xxxxxxxxxxxx-x Product Code: 0531493 ApeCoreSw: V 5.0706.4.0.1 05-02-07 RM-180 (C)Nokia ApeVariant: V 5.0706.4.0.1-APAC1 05-02-07 RM-180 (c)Nokia Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354568017557032 Version: SIMLOCK SERVER VERSION 58 Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN, DATA=23420F BLOCK 2: 1=OPEN, DATA=23594F BLOCK 3: 1=OPEN, DATA=23420F BLOCK 4: 1=OPEN, DATA=23594F Help me and guide what i can for this |
04-21-2010, 03:19 | #7435 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1287898 Status: Offline Thanks Meter: 0 | Hi, Just used SGT-S5230_MultiLoader_V5.56 to flushed my s5230. made a mistake and checked Boot change. Now phone cant boot, cant see the usb port. Pls how do make it boot again as well see the usb port. Thanks |
04-21-2010, 17:08 | #7437 (permalink) |
Crazy Poster Join Date: Nov 2007
Member: 639799 Status: Offline Thanks Meter: 3 | hi dear i have a 5140 and keep restarting as i change the battery and the same problem keep switching off every time you switch on it's turn on completely and then again turns off please i need help to fix this problem thanks never fix one before please help thanks i did clean the board . no trace of water board looks ok where is the problem thanks bye |
04-22-2010, 13:07 | #7440 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Hafizabad, Pakistan
Member: 269126 Status: Offline Sonork: 100.1616382 Thanks Meter: 370 | 6300 auto switch on problem hi there its big problem i have got nokia 6300 auto switch on and work fine..............i have remove the switch butt still same problem i have clean the board and putt it at lamp half an hour but got same any perfect soltuion on off switch ways are neet and clean and not shorted...........plzzzzzzzzzzzzzzzzzz provdie a better soluyion with daigram............. |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
