Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
![]() | #3647 (permalink) |
Major Poster ![]() ![]() Join Date: Jan 2007
Member: 431134 Status: Offline Thanks Meter: 6 | hi nokia 6230i white screen when press any butten then black i try flash but smae prb flsh errer not done thanks JAF version 1.98.64 Detected PKEY: 9xxxxx Card life counter: 37.37% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.16.0 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 03.70 09-Jan-06 RM-72 GSM P1.1 (c) NMP. HW version: 1000 PCI version: UEM version: 400 UPP version: 4178 RFIC version: p 10ff11ff0205 DSP version: p B0446T_05w14 LCD version: SHARP BT MCM version: 0382 ADSP version: TIKU_PB_04w47_06_w01 Production serial number: KLB552578 Product code: 0524422 Module code: 0202552 Basic production code: 0519797 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 355386xxxxxxx IMEI spare to net: 3A 55 83 06 90 62 15 00 IMEI SV to net: 33 55 83 06 90 62 15 10 F8 Master Code: 7557056336 Phone type: RM-72, Software version: 03.70, Language Pack: not available User code: 12345 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-72.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0524422 Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-72\ Scanning for ini files... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.890 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89C CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89.ucp_TMO_UK ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese Done! Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\355386xxxxxxxxx_imei_back up_326312.rpl Done! Backup imei OK! MCU: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.890 Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: ec Loader is ready... P-key nokia module version 01.02 MSID: 84C24E5244328271E4A803CDF3 MSID decoded: 80B0BAE9009AAD46A8000000 FAID: 31BC4C736D11CD3F96EF4C8B Operation took 0 minutes 10 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 009FFFFF... Erasing area: 00A00000 - 00B3FFFF... Erasing area: 00B60000 - 00FAFFFF... Operation took 2 minutes 25 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 0 seconds... Restarting MCU... NAND Format OK! CNT: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89.ucp_TMO_UK Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_oncsm.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5648; Loader chk: db Loader is ready... Operation took 0 minutes 6 seconds... Erasing Content Pack... Mass Memory Device Detected... MM Bus Configured... Formating MM...Format failed! Changing flashing settings... Setting local mode... Reading... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.890 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89C CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89.ucp_O2_DE_LOOP ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\355386xxxxxxxxxx_imei_bac kup_332312.rpl Done! Backup imei OK! MCU: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.890 Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: ec Loader is ready... P-key nokia module version 01.02 MSID: 84C24E5244328271E4A803CDF3 MSID decoded: 80B0BAE9009AAD46A8000000 FAID: 31BC4C736D11CD3F96EF4C8B Operation took 0 minutes 10 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 009FFFFF... Erasing area: 00A00000 - 00B3FFFF... Erasing area: 00B60000 - 00FAFFFF... Operation took 2 minutes 25 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 0 seconds... Restarting MCU... NAND Format OK! CNT: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89.ucp_O2_DE_LOOP Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_oncsm.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5648; Loader chk: db Loader is ready... Operation took 0 minutes 7 seconds... Erasing Content Pack... Mass Memory Device Detected... MM Bus Configured... Formating MM...Format failed! Waiting for the last operation to finish... |
![]() | #3650 (permalink) |
Junior Member ![]() Join Date: Dec 2007
Member: 658255 Status: Offline Thanks Meter: 21 | hi there, i dont know if i can ask it. i have just got a nokia E90. i bought it on internet, but when i put my sim card, it ask for Lock Code. i tried 12345 but wont work. Any idea? thnx |
Solving Your CDMA Problem Within 24 hours | kapil2007chakde | Various CDMA/TDMA Cell Phones | 770 | 04-20-2017 22:20 |
..::solve Your Problem Within 24 Hours::.. | RIZWANJAT | Nokia Hardware & Hardware Repair | 16 | 02-03-2013 08:50 |
