SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809. |
02-09-2006, 22:26 | #1 (permalink) |
Junior Member Join Date: Feb 2005 Location: Belgium
Member: 120677 Status: Offline Thanks Meter: 0 | Help D600 dead after flash Please, please, can someone help me. i'm desperate. |
02-10-2006, 16:18 | #2 (permalink) |
No Life Poster Join Date: Nov 2004 Location: In a Ganja plant! Age: 38
Member: 91298 Status: Offline Thanks Meter: 6 | If you can get another battery that's charged then we can fix it. Basically connect phone to onenand, and format the TFS - then fully flash the phone with the new battery on it. Once flashed disconnect - insert flat battery and charge it. Phone should be fine then. br, Danny. |
05-04-2006, 12:56 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: www.speedymobile.co.uk
Member: 255014 Status: Offline Thanks Meter: 39 | ?? Quote:
"Format the TFS"...YOU SAY....WHATS THIS MEAN?..SORRY, NEW TO SAMMY FLASHING Cheers, geezer13 | |
05-09-2006, 11:20 | #4 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 250890 Status: Offline Thanks Meter: 2 | hi geezer, do as mobile extreme suggested and then flash as you did before using only the d600.tfs file leaving the d600.cla file out! Alternatively use a fully charged phone battery and 9v battery and reflash as you did before and this will do the trick!! good luck! |
05-09-2006, 16:03 | #5 (permalink) |
Member: 91298 Status: Offline Thanks Meter: 6 | Hi, Flash both parts. If flashing failed becuase of flat phone battery, then how do you know its 100% successful flash. Basically full battery 9v - full phone battery. Connect to flasher, select CLA and TFS for flashing, load files, format NAND (tfs) then fully flash. Format NAND (TFS) will format the Tiny File System in the phone where all the menu's and icon's and templates / ringtones etc are stored, if you dont do this then your phone could act weird after a flash. ALSO - once flashed enter this code *2767*2878# this will do a Custom Eeprom Reset - this will help your phone after flashing and if the main menu is a bit funky it will reset this and will be ok. That's it! your D600 *swift phone, should be working. Post results br, Danny. |
D600 Dead after flashing | gastapoo | Samsung Hardware Repair | 2 | 07-17-2007 21:25 |
e730 and D600 dead after flashing | enzino | NSPRO | 3 | 02-01-2006 14:36 |
please help....savvy dead after flashing | zoboz | Philips | 8 | 11-22-2003 19:06 |
Plaese HELP A1018s dead after flash | cgavryusov | Old Ericsson Phones & Sony Phones | 2 | 07-09-2002 16:04 |
HELP!! t28 dead after flashing | nawikre | Old Ericsson Phones & Sony Phones | 17 | 12-24-2001 09:38 |
