SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809. |
03-02-2010, 00:58 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ES-Brazil
Member: 217679 Status: Offline Thanks Meter: 95 | Samsung M2710 while turning in the lock screen shows red numbers? I tried the procedure to handle the 9 key and connect the USB cable it asks a very strange drive that I have on my pc, even installing the package the samsung drives do not think this drive, the drive's name we ask is: NXP Semiconductors - Full Speed - DFU |
The Following User Says Thank You to cbcelular For This Useful Post: |
03-02-2010, 01:47 | #3 (permalink) |
Member: 217679 Status: Offline Thanks Meter: 95 | yes installed the drive was accepted, it did not create door so I can use the OneNAND Downloader v1.4 For the samsung only have hwk and hwk no model m2710 on the list, and tried to flash using the M2310 model and still same problem as reported above. |
03-02-2010, 01:58 | #4 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | maybe flasher is same like for L700 and J800 since they are from the same platform, here is it with driver inside. after u chose file, click "START" then connect phone (i mean do not connect phone before "START"). Flasher: http://www.megaupload.com/?d=UBSZU6S9 Guide: http://www.megaupload.com/?d=RVXFW8BG (start read from P8) br |
03-02-2010, 02:38 | #5 (permalink) | |
Member: 217679 Status: Offline Thanks Meter: 95 | Quote:
03-03-2010, 18:37 | #7 (permalink) |
Member: 217679 Status: Offline Thanks Meter: 95 | Yes I did the same mistake, I used the downloaded flash in support SarasSoft / HWK two files M2710VIIC2_H9.cla and M2710VIIC2_H9.tfs, it seems that the Flash program loader does not detect them as correct files and compatible with the program. Follow the images as I loaded the flash in different ways and always in error. |
03-03-2010, 19:06 | #9 (permalink) | |
Anything if you find something let me know I am very grateful! Thanks! | |
03-03-2010, 19:20 | #10 (permalink) |
Member: 111457 Status: Offline Thanks Meter: 967 | HWK use original flash file for all supported samsung. but they upload also Flash file for not supported samsung in their support. so problem is with Flasher not wioth flash file. br |
03-26-2010, 17:08 | #12 (permalink) |
Member: 217679 Status: Offline Thanks Meter: 95 | He left this week to update the HWK 2.1.0.0 and not yet solved the problem with my M2710 now the code in red is still more to other numbers "22023253" today does not resolve the problem has made several process format the NAND and NOR and erased without success, not reading it, I played and nothing E2P |
U600 locking in the initial screen | rmgoldner | UST Pro II | 1 | 05-19-2009 07:21 |
is there any app to n95 8gb changing the voice while talking in the phone | x-storm | Nokia Multimedia | 0 | 04-26-2009 17:38 |
E830 showing red number and blinking done | amalou | UST Pro II | 0 | 03-08-2009 15:57 |
alcatel 332 lcd very dark in the standby screen | hooi76 | Alcatel TCL Hardware Repair | 4 | 04-19-2004 13:11 |
