Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 09-07-2009, 13:46   #136 (permalink)
mistahk's Avatar
Member: 653932
Thanks Meter: 63
Originally Posted by everace View Post
hi, anyone knows how to install opera mini or other java based application
many thanks
RTFM for usual java loading
sometimes opera needs OTA installation
Old 09-17-2009, 15:38   #137 (permalink)
Member: 1121563
hey can ne 1 help me pls....... i successfully completed all d steps but after all dat der s no game in my phone....... i donno wat 2 do...... der r so many who ve asked dis earlier in d posts but der s no ans..... so pls pls help me.....
Old 11-08-2009, 18:51   #138 (permalink)
Member: 1156867
Stuck Part 7
Hi there
I am stuck at part:
7. Go to File - Connect. You should get the F480 File System Tree at TkFileExplorer bottom half side.
When I clic on Connect after part 6 the TkFileExplorer does not show the F480 File System Tree at the bottom, therefore I can't select "Exe"
Can you help please
Old 11-10-2009, 17:13   #139 (permalink)
Member: 1157807
hi
Can any1 answer my question, there's a port i click and when i go to file to connect it, it says warning! whats the problem?
Old 12-17-2009, 09:42   #140 (permalink)
Member: 1185654
Ok, you have successfully completed all the steps but you have to put the JAR AND the JAD files together in the created folder. Samsung requires the JAR and the JAD file.
Old 12-17-2009, 09:45   #141 (permalink)
Member: 1185654
Try press on menu on your F480 Tocco then press Settings > Phone Settings > PC connections and select Ask on connections and save.
Try and redo all the steps again
Old 12-17-2009, 09:46   #142 (permalink)
Member: 1185654
Originally Posted by fm11 View Post
Hi there
I am stuck at part:
Can you help please
Try to set your pc connections on your f480 tocco to ask on connections then redo again
Old 12-17-2009, 09:47   #143 (permalink)
Member: 1185654
And thanks to sensesme, i have installed 26 games on my F480 Tocco .
Old 01-22-2010, 21:09   #144 (permalink)
Member: 1216189
hi guys. i registered just to join this thread. anyway. i have a samsung F480 too. its F480JPHF2. can i flash it with any of the firmwares given on this thread?
Old 01-22-2010, 21:13   #145 (permalink)
Member: 1216189
Originally Posted by sensesme View Post
Other interesting thing:
TkFileExplorer allowed me to delete the 'built-in' game Photo Puzzle whitch is locked at F480 and cames inside folder /Exe/Java/Locked Games
WARNING:
Be careful with TkFileExplorer delete option!
it is a one-touch action!, it do not ask for confirmation.
i did find the game and deleted it BUT when i looked at my phone, the game was still there but its not working. so what it did was i deleted the whole locked games folder and when i looked again, it was still there. how do i delete that game?
Old 01-23-2010, 05:23   #146 (permalink)
Member: 1216411
Please help, im stuck :(
Im confused...the tutorial said if you scroll down there should be only one COMxx option. how come i have none? please help.
Old 02-11-2010, 17:59   #147 (permalink)
Member: 1233788
Exclamation
  1. Download Driver & File Explorer.
  2. Uncompress SAMSUNG_Composite_USB_Driver_4_34_WHQL.zip and execute Setup.exe.
  3. Connect F480 to PC. First time you should be prompted with a 'device installed and ready' message.
  4. Execute TkFileExplorer_2.2.exe
  5. Go to Settings - COM.
  6. Scroll down Port window: You should get just one COMxx option. Choose it and press OK.
  8. Go to /Exe/Java/Games
  9. Create a New Folder for your game
  10. At TkFileExplorer PC upper side select game JAD/JAR files and copy to F480 created folder using drag&drop or right button menu Download option.
  11. Repeat steps 9 & 10 for all games you want to install at a time.
  12. Disconnect USB cable
  13. Dial *#6984125*#
  14. Go to Internals (Master Key: *#9072641*#)
  15. Go to Storage Settings and select Update Java DB
Enjoy! ...and save money!
NOTE 1:
You do not need to change Samsung USB mode to Qualcomm. Leave it at its default Samsung mode (if you do not understand this just do nothing )
NOTE 2:
Once driver is installed, Samsung PC Studio 3 still works.
SOURCE:
http://www.forummobiles.com/index.ph...=160797&st=896
When I attempt to select port it comes up blank no port visible.
PC Studio 3 works fine sync ECT......so if there is an issue PC Studio would not either.
Why id there no port showing?
All the drivers I have installed as explained here still no go
Old 02-13-2010, 10:17   #148 (permalink)
Member: 1185654
you have to go your phone, press settings, phone settings, pc connections, and select ask on connection. then put in the cable to your phone and see your phone screen . it will have something pop out then u select samsung pc studio. then continue your steps
Old 02-13-2010, 16:31   #149 (permalink)
Member: 1233788
Angry Connect to TkFileExplorer does not show post
I have followed all the step, from the phone except it does not show port on TkFileExplorer still not port just bland, PC Studio work fine with the phone, so if there is a issue the this part will not work.
I know this is easy how without a port a go nowhere fast.
Old 02-13-2010, 16:32   #150 (permalink)
Member: 1233788
Angry Connect to TkFileExplorer does not show port!
I have followed all the step, from the phone except it does not show port on TkFileExplorer still not port just blank, PC Studio work fine with the phone, so if there is a issue the this part will not work either.
I know this is easy however without a port I am stuck, go nowhere fast.
Free Video Tutorial : How to Update Genie Universal Firmware & Software fonefun Genie Universal 0 02-12-2010 21:30
Hardware & software Teacher/all Video and other Tutorials GSM-DOCTOR GSM Mobile Links 11 02-22-2009 14:28
Software/App/Game install without hotsync, How to Dashar PalmOS /HP and others 12 12-19-2008 21:03
-= Samsung E570 java install tutorial =- amonev Samsung Media, Games, Ringtones 0 11-18-2007 13:47
java soft by wap scurt Java, iOS, Android, Symbian development 1 06-10-2003 17:57
Page generated in 0.26431 seconds with 9 queries
