x700 is Trident/AGERE Platform and f480 is qualcomm so I gues it won't work, but of course you may try |
Dump memory Hi How can I dump phone memory? Because I have samsung F480 and I want to help you with "Java problem" :] |
it's all written earlier, just enough to read! if you're polish then take a look @ samsung-mobile.pl |
I have to apoligize but since I successfully started to dump memory I haven’t found the chance to leave my phone connected to computer for more than 20 hours. Mistahk give us all the keys to dump memory and it woks. Here a full checklist. At F480 Dial: *#0523# Press several times ‘#’ key until you get a menu. Press volume-down button until you get a menu with option: ‘[6] USB Configuration’ Press ‘6’ key At next menu select ‘[2] Qualcomm USB[]’ Connect F480 to PC At PC Follow Mistahk post #28 of current thread See what I say at post #35 about COM port. Good luck and take your time. |
i just started dumping z400 again, cos i'm making a new mod 2.0 so i see how long does it take with it, maybe you will have some free time, you can normally use the phone, so call or answer the phones the only minus it's it had to be connected to the cable, anyways thanks for trying regards |
Thanks a lot for taking this.. but any luck guys.. awaiting your answer.. |
awaiting memory dump from anyone.. besides I got a meesage today, samsung officialy claims that on tocco run only games made for midp 2.0 and touch technology |
Well... I also want to know how to install games by using the USB or bluetooth, cause all the games i got, was by downloading it via wap, which is not always safe, cause some of the games may not work on the phone, and it will be just a waste of money !!!. I installed the game " Bejeweled Deluxe " by gameloft.... it starts fine, and i can see the menu, but when i select the first option... the game freezes... and cannot do anything else that just close it. I can play : Bubble Popper Deluxe, Rayman Kart, Brain Challenge 2, Block Breaker Deluxe, Diamond Rush, Wonder Blocks, Explode!. That´s all I have on my phone working properly. I also installed Alpha Wing 2, and starting is fine, but when the game is going to start.. it also freezes. I got Bubble Bash, I can tap on all the menus, but then when i need to play.. i cannot move the arrow or shoot the ball... Anyone got the same problem with Bejeweled Deluxe ? I really want that game xD. Ohh... and I know how to delete that annoying bar when u want to play touch screen games ;) If you are interest just let me know... But u can´t delete that pad if u play a non touch screen game hehe. |
http://www.mobile9.com/invboard/inde...5&#entry512707 go to post #20 |
It was 2:47 AM in HK, and i was so sleepy, so no time to find the information with the details. Anyways, someone else already got it :P. |
Here more direct.... Just edit the MANIFEST file, zipped in the JAR file and add the line: MIDlet-Touch-Support: True So you just open the JAR file with winrar, then find MANIFEST, open with notepad and add the line MIDlet-Touch-Support: True Save the file, re-ZIP the files and rename back to a JAR file. This should remove the bar. |
thx 4 the info might be useful [; |
