QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
12-01-2010, 09:38 | #1 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | I900 Flash dead Download failed!! PDA Device 1 ready to download! ok PHONE will be written. dead PHONE will be written. ------------------------------------------------------------------------------------- Downloading PHONE... KW.KIM Create retry(25) KW.KIM Create retry(24) KW.KIM Create retry(23) KW.KIM Create retry(22) KW.KIM Create retry(21) KW.KIM Create retry(20) KW.KIM Create retry(19) KW.KIM Create retry(18) KW.KIM Create retry(17) KW.KIM Create retry(16) KW.KIM Create retry(15) KW.KIM Create retry(14) KW.KIM Create retry(13) KW.KIM Create retry(12) KW.KIM Create retry(11) KW.KIM Create retry(10) KW.KIM Create retry(9) KW.KIM Create retry(8) KW.KIM Create retry(7) KW.KIM Create retry(6) KW.KIM Create retry(5) KW.KIM Create retry(4) KW.KIM Create retry(3) KW.KIM Create retry(2) KW.KIM Create retry(1) KW.KIM Create retry(0) Download failed!! |
12-01-2010, 09:52 | #3 (permalink) |
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | Calculating file parameters(DISKIMAGE).... Calculating file parameters(DISKIMAGE) Done!! Analyzing the Combined Image... Wrote to C:\_eboot.nb0 successfully Wrote to C:\_phone.bin successfully Wrote to C:\_xip0.nb0 successfully Done!! Calculating file parameters(DISKIMAGE).... Calculating file parameters(DISKIMAGE) Done!! OnDeviceChange: DBT_DEVICEARRIVAL ------------------------------------------------------------------------------------- PDA Device 1 ready to download! ------------------------------------------------------------------------------------- PDA 1 starts downloading... Don't plug it out until the label becomes blue!!! ------------------------------------------------------------------------------------- EBOOT will be written. Total 1 PDA region(s) will be written . PHONE will be written. ------------------------------------------------------------------------------------- Commanding Device Large Disk Format... Downloading EBOOT... PDA Reboot to download Eboot twice!!! ------------------------------------------------------------------------------------- OnDeviceChange: DBT_DEVICEARRIVAL ------------------------------------------------------------------------------------- PDA Device 1 ready to download! ------------------------------------------------------------------------------------- PDA 1 starts downloading... Don't plug it out until the label becomes blue!!! ------------------------------------------------------------------------------------- EBOOT will be written. Total 1 PDA region(s) will be written . PHONE will be written. ------------------------------------------------------------------------------------- Commanding Device Large Disk Format... Downloading EBOOT... EBOOT finished!! Downloading PDA region #1(DISKIMAGE)... PDA Write count : 980 PDA finished!! Writing dummy CSC header... Downloading PHONE... KW.KIM Create retry(25) KW.KIM Create retry(24) KW.KIM Create retry(23) KW.KIM Create retry(22) KW.KIM Create retry(21) KW.KIM Create retry(20) KW.KIM Create retry(19) KW.KIM Create retry(18) KW.KIM Create retry(17) KW.KIM Create retry(16) KW.KIM Create retry(15) KW.KIM Create retry(14) KW.KIM Create retry(13) KW.KIM Create retry(12) KW.KIM Create retry(11) KW.KIM Create retry(10) KW.KIM Create retry(9) KW.KIM Create retry(8) KW.KIM Create retry(7) KW.KIM Create retry(6) KW.KIM Create retry(5) KW.KIM Create retry(4) KW.KIM Create retry(3) KW.KIM Create retry(2) KW.KIM Create retry(1) KW.KIM Create retry(0) Download failed!! |
12-01-2010, 16:56 | #5 (permalink) |
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | Port Open Failed” message or application hang After you install “phone USB driver (Samsung CDMA Modem)” at first time, you m ay see “Port open failed…” message or application hang while downloading a phone image. If so, terminate the application and then try the download again. If USB port is changed, at first time you may see “Port open failed…” message or application hang. If so, terminate the application and then try the download again. If USB cable to the mobile device is not connected tightly, you may see “Port ope n failed…” message or application hang. If so, terminate the application and then try the download again. . If you always see “port open failed” message or application hang, 1. When failed application is activated, go to the device manager, remove the S AMSUNG CDMA Modem and SAMSUNG USB Composite Device. 2. Rename C:\WINDOWS\system32\drivers\Modem.sys to other name. (ex. Mod em-.sys) 3. Go to control panel->program add/remove, and then remove Samsung CDMA Modem driver or Samsung USB driver(MCCI) 4. Restart your PC. 5. Install attached SAMSUNG CDMA Modem_4.34 6. Try the download again. 3. “Write Failed” message If battery level is low, use charged battery and try again. KW.KIM Create retry(0) Download failed!! |
12-11-2010, 16:38 | #8 (permalink) |
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | ***************************************** Select: JTAG REPAIR TOOL Check Connection: Found Target, Target Info: - HW_REVISION_NUMBER: 0xA00C00E1 ***************************************** Erase Boot: Found Target, Target Info: - HW_REVISION_NUMBER: 0xA00C00E1 - MCP NAND ID: EC 76 - Chip: Samsung K9k1208d0c(u0a)/K9K1G08/ 512 Mbit Flash Map: - Block Count: 0x1000 - Block Size: 0x20 pages - Page Size: 0x200 bytes - Total Page Size: 0x210 - Erase Boot... Done! ***************************************** File: i900_msm6281_Modem_Boot_Repair.qbf Modele: i900 Write Boot (QBF): Found Target, Target Info: - HW_REVISION_NUMBER: 0xA00C00E1 - MCP NAND ID: EC 76 - Chip: Samsung K9k1208d0c(u0a)/K9K1G08/ 512 Mbit Flash Map: - Block Count: 0x1000 - Block Size: 0x20 pages - Page Size: 0x200 bytes - Total Page Size: 0x210 Calculate Space ...Done! Write Partition: - 0:AMSS ...Success! - 0:OEMSBL2 ...Success! - 0:OEMSBL1 ...Success! - 0:QCSBL ...Success! - 0:MIBIB ...Success! ***************************************** Download failed!! Calculating file parameters(DISKIMAGE).... Calculating file parameters(DISKIMAGE) Done!! Analyzing the Combined Image... Wrote to C:\_eboot.nb0 successfully Wrote to C:\_phone.bin successfully Wrote to C:\_xip0.nb0 successfully Done!! Calculating file parameters(DISKIMAGE).... Calculating file parameters(DISKIMAGE) Done!! OnDeviceChange: DBT_DEVICEARRIVAL ------------------------------------------------------------------------------------- PDA Device 1 ready to download! ------------------------------------------------------------------------------------- PDA 1 starts downloading... Don't plug it out until the label becomes blue!!! ------------------------------------------------------------------------------------- EBOOT will be written. Total 1 PDA region(s) will be written . PHONE will be written. ------------------------------------------------------------------------------------- Commanding Device Large Disk Format... Downloading EBOOT... PDA Reboot to download Eboot twice!!! ------------------------------------------------------------------------------------- OnDeviceChange: DBT_DEVICEARRIVAL ------------------------------------------------------------------------------------- PDA Device 1 ready to download! ------------------------------------------------------------------------------------- PDA 1 starts downloading... Don't plug it out until the label becomes blue!!! ------------------------------------------------------------------------------------- EBOOT will be written. Total 1 PDA region(s) will be written . PHONE will be written. ------------------------------------------------------------------------------------- Commanding Device Large Disk Format... Downloading EBOOT... EBOOT finished!! Downloading PDA region #1(DISKIMAGE)... PDA Write count : 980 PDA finished!! Writing dummy CSC header... Downloading PHONE... KW.KIM Create retry(25) KW.KIM Create retry(24) KW.KIM Create retry(23) KW.KIM Create retry(22) KW.KIM Create retry(21) KW.KIM Create retry(20) KW.KIM Create retry(19) KW.KIM Create retry(18) KW.KIM Create retry(17) KW.KIM Create retry(16) KW.KIM Create retry(15) KW.KIM Create retry(14) KW.KIM Create retry(13) KW.KIM Create retry(12) KW.KIM Create retry(11) KW.KIM Create retry(10) KW.KIM Create retry(9) KW.KIM Create retry(8) KW.KIM Create retry(7) KW.KIM Create retry(6) KW.KIM Create retry(5) KW.KIM Create retry(4) KW.KIM Create retry(3) KW.KIM Create retry(2) KW.KIM Create retry(1) KW.KIM Create retry(0) Download failed!! http://forum.gsmhosting.com/vbb/f625...oblem-1155300/ |
12-29-2010, 03:43 | #11 (permalink) |
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | ***************************************** Select: JTAG REPAIR TOOL Check Connection: Found Target, Target Info: - HW_REVISION_NUMBER: 0xA00C00E1 ***************************************** Erase Boot: Found Target, Target Info: - HW_REVISION_NUMBER: 0xA00C00E1 - MCP NAND ID: EC 76 - Chip: Samsung K9k1208d0c(u0a)/K9K1G08/ 512 Mbit Flash Map: - Block Count: 0x1000 - Block Size: 0x20 pages - Page Size: 0x200 bytes - Total Page Size: 0x210 - Erase Boot... Done! ***************************************** File: i900_msm6281_Modem_Boot_Repair.qbf Modele: i900 Write Boot (QBF): Found Target, Target Info: - HW_REVISION_NUMBER: 0xA00C00E1 - MCP NAND ID: EC 76 - Chip: Samsung K9k1208d0c(u0a)/K9K1G08/ 512 Mbit Flash Map: - Block Count: 0x1000 - Block Size: 0x20 pages - Page Size: 0x200 bytes - Total Page Size: 0x210 Calculate Space ...Done! Write Partition: - 0:AMSS ...Success! - 0:OEMSBL2 ...Success! - 0:OEMSBL1 ...Success! - 0:QCSBL ...Success! - 0:MIBIB ...Success! ***************************************** KW.KIM Create retry(1) KW.KIM Create retry(0) Download failed!! not workin jtak |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Upload / Download eeprom program for 51xx/61xx | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-07-1999 14:03 |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
