QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
04-14-2005, 16:14 | #46 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | USB Connector S100 Connector 1 GND(black)----------------- 5 2 D1 (green)---------------- 18 3 D0 (white)---------------- 16 4 +5V (red)----------------- 19 I have connected correctly according to this pinout, but I have no luck. While on another tutorial that I found on the web named: "z105 detailed phone freeze remove tutorial" there is told that you must use the s100 connector, and we all know that S100 has a completely different pinout from that above mentioned by me. Any advice would be appreciated. |
04-22-2005, 13:54 | #49 (permalink) |
Major Poster Join Date: Oct 2002 Age: 55
Member: 16457 Status: Offline Thanks Meter: 41 | 1. Download correct Driver Modem http://org.downloadcenter.samsung.co...o_for_Z10x.exe 2. Referring to the z105cable.rar there is this pinout: USB Connector S100 Connector 1 GND(black)--5. 2 D1 (green)--18. 3 D0 (white)--16 4 +5V (red)--19 3. Built Dongle com port with short pin 2&3 4. Phone ON--select Unlock -- Pass Working with QIWS_V1.16(Service)_041011.exe |
05-04-2005, 20:52 | #51 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Algeria Age: 41
Member: 26438 Status: Offline Thanks Meter: 8 | Hi! (Urgent) I want to know how to lock this Z107v to its original operator? I tried lock function, but doesn't help? 'cause I unlocked this Z107v, and I want to relock it!!! |
05-04-2005, 21:29 | #52 (permalink) | |
Member: 26438 Status: Offline Thanks Meter: 8 | Quote:
Relocked-back Thanks, bye | |
05-07-2005, 23:32 | #54 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 44
Member: 61643 Status: Offline Thanks Meter: 14 | If you are locking for samung z107 unlock sollution, why don't you just try with same program that you have when unlocking a z105? simple use. com connector and short tx and rx pin 2-3 on the (com) use samsung original usb cable PCB157ULE 1. plug in phone install usb drivers 2. open QIWS_V1.16(Service)_041011.exe 3. plug in com adapter (tx and rx shorted) 4. check if program finds samung modem. (if not found, go back to 1) 5. press ok 6. press unlock, (if you get usb error try to go to 4 and change the usb comport manualy to something else) 7. if phone unlocked insert a gsm card (if you have problem with network just change it manualy to gsm instead of automatic) links for program and cable information can be found here... http://forum.gsmhosting.com/vbb/showthread.php?t=173873 i have nothin more to say... exept.... why but agere attack when they probably use same sollution themself for z105 and z107 |
i ned Samsung Z105 UNLOCK SOLLUTION FREE | touta1 | QUALCOMM Models (3G) | 0 | 09-18-2008 17:48 |
Help Samsung Z107 Unlock | blueaurabd | QUALCOMM Models (3G) | 5 | 06-29-2007 12:35 |
Samsung Z107 Unlocking | afrodizzy | FuriouS II | 7 | 11-18-2005 20:51 |
Samsung E800 Unlock Code, Free | gaz_0001 | SYSOL Platform | 10 | 05-04-2005 21:31 |
samsung d500 unlocking for free | ronnyj1 | SWIFT Platform | 4 | 12-18-2004 10:33 |
