Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 10-28-2005, 14:55   #1 (permalink)
Keke's Avatar
Member: 12733
Thanks Meter: 26
Z500 imei Change , The final SAY ::::::
HI To All .
I have been reading around for the possibility of changing imei on Z500.
But realy I do not understand one thing ; Is this possible or not ?
Some said solution
-Use Lg 3g usb+com cable
-Use lg 7050
-use E720 usb cable
-And Bla bla bla .....
-And bla bla bla ....
Use com cable only (where is the pinout)
Yes unlock and reset phone no problem but imei change : How
Lolly POP did you find solution yet ? I know you have been looking also .!!!!
Yes please elco give us sollution Here.
keke
Old 10-31-2005, 17:24   #2 (permalink)
Keke's Avatar
Member: 12733
Thanks Meter: 26
Wow so This means that it is true !!!!
No solution for the moment
Old 11-01-2005, 15:04   #3 (permalink)
Member: 38782
Thanks Meter: 9
Yes, of course it's possible..
Old 11-01-2005, 15:06   #4 (permalink)
Member: 39112
Thanks Meter: 4
use lg7050 com cable with 9v supply work test by me
Old 11-01-2005, 15:55   #5 (permalink)
Member: 32195
Thanks Meter: 5
100% confirmed.. 7050 com cable works!!!!!!!!!!!!!!
this is the definative solution!!!!!!!!!!!
Old 11-01-2005, 16:21   #6 (permalink)
Keke's Avatar
Member: 12733
Thanks Meter: 26
I have 5 in one lg set and stand alone lg 7050 cale and noe of them is working and also what software are u using , I have tried any possible software also and still no way.
Anyway I have no phone try again now but can anyone post a working pinout here ?
Thanks
keke
Old 11-01-2005, 17:28   #7 (permalink)
Member: 39112
Thanks Meter: 4
i use ns dongle and work fine
Old 11-01-2005, 17:40   #8 (permalink)
Registered User
mr_x4you's Avatar
Member: 4989
Thanks Meter: 13
Thanks
keke
Heh, once was enough I think !
Old 11-02-2005, 07:53   #9 (permalink)
Keke's Avatar
Member: 12733
Thanks Meter: 26
Yeah
I am sorry about that my pc was freezing.
keke
Old 11-11-2005, 07:02   #10 (permalink)
Member: 72851
Thanks Meter: 28
Can anyone confirm using what cable ???
And using what software ??
Seem like no actual answer for everthing
Best Regard
Gsm-W
Old 11-11-2005, 07:24   #11 (permalink)
Keke's Avatar
Member: 12733
Thanks Meter: 26
Best Regard
Gsm-W
Now I know there is no solution for this and for now.
Cause no one can confirme the solution :
Use usb cable and short pin 2 amd 3 : "cale date" issue
use lg 7020/7050 cable: Com port ok , usb port not find.
Now what ?
keke
Old 11-11-2005, 14:04   #12 (permalink)
Member: 153020
ive done the imei on the Z500 today and im still pulling my hair out !!!!
Did it using a Z130 original data cable and a LG 7050 9v battery cable with NS DONGLE I changed the imei number twice and when I tried a 3rd time it will not do it at all........
Im pulling my hair out now, tried everything... all the coms that show on the NS Dongle, tried it on 3 computers, tried win imei programs with all the data cables but still no joy....
If anyone is wondering why im trying to change the number a 3rd time its because I put all the 3's in and now it only works on Orange not Voad !!
ANY IDEAS ANYONE ....
Old 11-11-2005, 17:52   #13 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,395
1.Connect powered off phone to cable.Phone must power on by himself(if you have correct cable)
2.Start nsdongle v3.8.12
3.Select Z500 and write IMEI.
PS. Phone must be WITHOUT sim
Old 11-11-2005, 18:23   #14 (permalink)
The Repair Shop's Avatar
Member: 307549
Thanks Meter: 188
Elco who has these cables in stock do you know
Old 11-11-2005, 18:42   #15 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
I dont know.But you can find the pinout on support zone and the cable is very easy to build.
Z500 Imei Change hans salim UST Pro II 5 11-11-2006 20:50
z500 / z105 imei change problem lolly_pop QUALCOMM Models (3G) 2 08-08-2006 10:10
z500 imei changing software lolly_pop QUALCOMM Models (3G) 2 12-11-2005 18:45
Z500 Imei change ? aj4u QUALCOMM Models (3G) 0 10-02-2005 11:22
Z300 / Z500 IMEI change after Flash Apocalysse QUALCOMM Models (3G) 1 07-16-2005 10:43
Page generated in 0.36792 seconds with 9 queries
