6235 cable 6100 cable for 6235 -------------------------------------------------------------------------------- hi friends convert ur nokia 6100 cable for cdma 6235 first unscrew the cable,remove the upper cover and place it inside phone,now watch on the rigt side u have to cut down the width around 3mm now the cable can b shifted to right side so that the pins should now touch the golden points exactly, click the check button on ufs-3/jaf...it shud display first boot ok fine ur cable is ready to flash/unlock etc see this result on JAF with PKey ------------------------------------- Unpacking in C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01 Please wait... Done unpacking nfp file...Selecting files... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00.nep PPM Flash file: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00.lgp CNT Flash file: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00_nok.ucp_ga ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00.nep PPM Flash file: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00.lgp CNT Flash file: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00_nok.ucp_ga ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE MCU: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00.nep Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.34.00 -> Revision: 0007 Boot size is 0x2338 Boot is ready... FLASH ID0: EC00FE22 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 00000100 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22FE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.34.00 -> Revision: 0007 Loader size is 0x8290; Loader chk: 25 Loader is ready... P-key nokia module version 01.00 MSID: 846A6D2AE985EC6F50D65420A5 MSID decoded: 2C40BAE900D0F8F9AF000000 FAID: 3D3853A0CA91D8440F7406A5 Operation took 0 minutes 15 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 009FFFFF... Erasing area: 00A00000 - 00ABFFFF... Erasing area: 00AC0000 - 00B8FFFF... Erasing area: 01DE0000 - 01FDFFFF... Operation took 1 minutes 32 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 5 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00_nok.ucp_ga Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.34.00 -> Revision: 0007 Boot size is 0x2338 Boot is ready... FLASH ID0: EC00FE22 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 00000100 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22FE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.34.00 -> Revision: 0007 Loader size is 0x8290; Loader chk: 25 Loader is ready... P-key nokia module version 01.00 MSID: 84D586FD683296969795E964A1 MSID decoded: CAB3BAE900D0F8F9AF000000 FAID: B3C09051AF54FD99BB86D750 Operation took 0 minutes 15 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 00BA0000 - 00DDFFFF... Operation took 0 minutes 15 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Extracting Content Pack... Phone current mode 04 Running: (c) Nokia File Server CNT Extract OK. Operation took 0 minutes 9 seconds... PPM: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00.lgp Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.34.00 -> Revision: 0007 Boot size is 0x2338 Boot is ready... FLASH ID0: EC00FE22 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 00000100 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22FE00EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.34.00 -> Revision: 0007 Loader size is 0x8290; Loader chk: 25 Loader is ready... P-key nokia module version 01.00 MSID: 842B789A2DDED0B286033364E2 MSID decoded: 3E4EBAE900D0F8F9AF000000 FAID: A72C2EDD9BBE3504219898A5 Operation took 0 minutes 16 seconds... Erasing PPM... Found 1 interval(s) to erase Erasing area: 00BA0000 - 00DDFFFF... Operation took 0 minutes 15 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 10 seconds... Restarting MCU... Flashing Done! Operation took 4 minutes 31 seconds... After flash processing... Waiting for phone to boot... Phone current mode 04 Reading... Phone type: RM-60, Software version: S190V0200.nep ESN: 026006xxxxx Product Code: 0523815 Resetting PPC... Done! wbr aksingh +919810222476 |
hi aksingh can you give me 6235 file... i urgent need this firmwawre. i really thanks for u if u wanna give me. how about we trade with another files u need? maybe i have... thanks |
thank bro it's work for me |
good its working perfectly |
nope. i think use ur brain... pin out at 6100 more wide than 6235... so u must modif so can connect properly.. please check itself 6100 with 6235... |
hellow sir need help nokia 3205(RIM) do not show network after manually reset(*#7370#) |
6235 model is not in ufs so no bady can flash it .if somebody want flashing through ufs so they have to purchase MobileEx software . i think it is best software because it so cheap and supporting cdma and adsp flashing also |
but it is ruim file |
use 6255 in ufs model selection ,to flash 6235 wbr aksingh |
solutions Quote:
write full pm on it will be ok wbr n.i.t [email protected] |
load pm then upload tun frm phoenix |
looking for 6235 flash file for RUIM Hi There, I am desperately looking for flash file for Nokia 6235 RUIM. I tried the link which was given above... http://www.em-5.net/DownSoftList/522...235_01_NFP.exe But this is just downloading a file of 1.3KB... Can someone please please put the flash file on download servers like rapidshare? Also, please give me some guide as to how to use the flash file. Thanks a ton for your help!! Amit Bhavsar |
help me! 6255 use cable same model gsm? i need pinout it. thanks |
here is flash file for nokia 6235 cdma ruim tested and ready to work with ufs http://www.gsm4yemen.com/support/NOKIA/6235/6235.zip wbr masterdevil |
