Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia CDMA
Old 06-03-2006, 17:37   #1 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
6235 cable
6100 cable for 6235
hi
friends
convert ur nokia 6100 cable for cdma 6235
first unscrew the cable,remove the upper cover and place it inside phone,now watch on the rigt side u have to cut down the width around 3mm now the cable can b shifted to right side so that the pins should now touch the golden points exactly,
click the check button on ufs-3/jaf...it shud display first boot ok
fine ur cable is ready to flash/unlock etc
see this result on JAF with PKey
Unpacking in C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01
Please wait...
Done unpacking nfp file...Selecting files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00.nep
PPM Flash file: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00.lgp
CNT Flash file: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00_nok.ucp_ga
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
MCU: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00.nep
Booting phone...
MCU ID: 0x1052
BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
Loader version: 04.34.00 -> Revision: 0007
Boot size is 0x2338
Boot is ready...
FLASH ID0: EC00FE22 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 00000100 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
Flash ID is 0x22FE00EC
Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
Loader size is 0x8290; Loader chk: 25
Loader is ready...
P-key nokia module version 01.00
MSID: 846A6D2AE985EC6F50D65420A5
MSID decoded: 2C40BAE900D0F8F9AF000000
FAID: 3D3853A0CA91D8440F7406A5
Operation took 0 minutes 15 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 009FFFFF...
Erasing area: 00A00000 - 00ABFFFF...
Erasing area: 00AC0000 - 00B8FFFF...
Erasing area: 01DE0000 - 01FDFFFF...
Operation took 1 minutes 32 seconds...
Writing...
Perm. Data Restore OK
Operation took 1 minutes 5 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00_nok.ucp_ga
Booting phone...
MCU ID: 0x1052
Boot size is 0x2338
Boot is ready...
Loader is ready...
MSID: 84D586FD683296969795E964A1
MSID decoded: CAB3BAE900D0F8F9AF000000
FAID: B3C09051AF54FD99BB86D750
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 00BA0000 - 00DDFFFF...
Writing...
Operation took 0 minutes 9 seconds...
Restarting MCU...
Operation took 0 minutes 1 seconds...
Extracting Content Pack...
Phone current mode 04
Running: (c) Nokia File Server
CNT Extract OK.
PPM: C:\Program Files\Nokia\CDMA\nfp\TKI_S190V0200_6235_01\S190V02 00.lgp
Booting phone...
MCU ID: 0x1052
Boot size is 0x2338
Boot is ready...
Loader is ready...
MSID: 842B789A2DDED0B286033364E2
MSID decoded: 3E4EBAE900D0F8F9AF000000
FAID: A72C2EDD9BBE3504219898A5
Operation took 0 minutes 16 seconds...
Erasing PPM...
Writing...
Operation took 0 minutes 10 seconds...
Restarting MCU...
Flashing Done!
Operation took 4 minutes 31 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RM-60, Software version: S190V0200.nep
ESN: 026006xxxxx
Product Code: 0523815
Resetting PPC...
Done!
wbr
aksingh
+919810222476
Old 06-04-2006, 07:04   #2 (permalink)
Member: 276718
Thanks Meter: 2
hi aksingh can you give me 6235 file...
i urgent need this firmwawre.
i really thanks for u if u wanna give me.
how about we trade with another files u need?
maybe i have...
thanks
Old 06-08-2006, 04:10   #3 (permalink)
Member: 137670
Thanks Meter: 12
thank bro it's work for me
Old 06-08-2006, 22:24   #4 (permalink)
Crazy Poster
Member: 278639
good its working perfectly
Old 06-10-2006, 11:34   #5 (permalink)
Member: 276718
Thanks Meter: 2
nope. i think use ur brain...
pin out at 6100 more wide than 6235...
so u must modif so can connect properly..
please check itself 6100 with 6235...
Old 06-15-2006, 12:59   #6 (permalink)
sallupat's Avatar
Member: 138982
Thanks Meter: 138
hellow sir
need help
nokia 3205(RIM) do not show network after manually reset(*#7370#)
Old 06-17-2006, 18:10   #7 (permalink)
akhileshbaghel's Avatar
Member: 84807
Thanks Meter: 67
6235 model is not in ufs so no bady can flash it .if somebody want flashing through ufs so they have to purchase MobileEx software . i think it is best software because it so cheap and supporting cdma and adsp flashing also
Old 06-17-2006, 23:19   #8 (permalink)
Member: 84807
Thanks Meter: 67
maybe i have...
thanks
http://www.em-5.net/DownSoftList/522...235_01_NFP.exe
but it is ruim file
Old 08-21-2006, 21:22   #9 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
sorry for late quote
use 6255 in ufs model selection ,to flash 6235
wbr
aksingh
Old 08-26-2006, 14:25   #10 (permalink)
N.I.T's Avatar
Member: 204243
Thanks Meter: 67
Smile solutions
Originally Posted by sallupat View Post
hellow sir
need help
write full pm on it will be ok
wbr
n.i.t
[email protected]
Old 09-02-2006, 11:14   #11 (permalink)
Member deceased !!
Member: 332583
Thanks Meter: 13
load pm then upload tun frm phoenix
Old 09-03-2006, 20:37   #12 (permalink)
Member: 295665
Red face
wbr
n.i.t
[email protected]
what is the address for ful pm.i mean to say that from where it starts and where it should enplz explain me clearly.i need it...
Old 02-05-2007, 05:48   #13 (permalink)
Member: 446171
looking for 6235 flash file for RUIM
Hi There,
I am desperately looking for flash file for Nokia 6235 RUIM. I tried the link which was given above...
But this is just downloading a file of 1.3KB... Can someone please please put the flash file on download servers like rapidshare? Also, please give me some guide as to how to use the flash file.
Thanks a ton for your help!!
Amit Bhavsar
Old 02-10-2007, 02:47   #14 (permalink)
nxc
Member: 68597
Thanks Meter: 6
help me!
6255 use cable same model gsm? i need pinout it.
thanks
Old 03-26-2007, 00:48   #15 (permalink)
Member: 36878
Thanks Meter: 23
here is flash file for nokia 6235 cdma ruim
tested and ready to work with ufs
http://www.gsm4yemen.com/support/NOKIA/6235/6235.zip
wbr
masterdevil
Cable 6235 ?????? JONAH7777777 Nokia CDMA 3 01-11-2009 00:59
Cable 6235 ?????? JONAH7777777 Nokia CDMA 2 01-09-2009 21:37
6235 cable a7mad01 Nokia CDMA 1 08-21-2006 21:23
6100 cable for 6235 ~AKSingh~ Various CDMA/TDMA Cell Phones 0 06-03-2006 17:23
Page generated in 0.27162 seconds with 9 queries
