12-18-2009, 17:39 | #1 (permalink) |
Freak Poster Join Date: Apr 2003 Location: Dublin Age: 43
Member: 25852 Status: Offline Thanks Meter: 31 | B3310 Solution that worked for me First download flash file for example this one http://www.megaupload.com/?d=0JP5T71T Go to ust chose model b3310 then convert orginal flash to UST format chose *.s3 file take out battery plug usb cable and press * and -volume put in the batterry phone should start and show connection logo you should hear usb plug sound go to hardware manger and find in com ports your phone change port to range from 1 to 10 (it should work on higher ports in UST v10 but i did it on com 2) now in UST chose your converted flash and flash phone , after flashing you need to restart phone . Now i had some problems with unlocking by ust but i used Samsung remote client and i did unlock no problems IMEI ok and evrything look to work just fine . Its not great soultion but has to do until they update UST . |
The Following 3 Users Say Thank You to kobolt For This Useful Post: |
Touchscreen Bypass damaged calibration solution 100% work for me!!! | kalpeshoza | Infinity-Box | 17 | 01-06-2010 20:07 |
Something that worked for me. | Mikie274 | HWK | 3 | 12-15-2007 11:57 |
Bios lpt setting that worked for me | Sethxp | Phoenix Black Box | 1 | 04-16-2005 09:37 |
Code that worked for me. | Tyzzie | NEC | 24 | 07-23-2004 15:36 |
4 locks closed solution - this work for me | gladeo | Sony Ericsson | 11 | 05-21-2003 13:05 |
