04-14-2007, 03:13 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 52
Member: 52425 Status: Offline Thanks Meter: 22 | e250 imei repair problem Power ON phone... Phone detected! Loading Preloader... Preloader OK! Setting 921600 bps... Baudrate set OK! Loading second loader... 2nd boot OK! Getting Flash ID... Manufactor : SAMSUNG Chip Type : KAP29SN00M Bypassing MSL security... MSL security bypass failed! Possible damaged eeprom data, Try again or write new eeprom. Elapsed Time (00:53 |
04-14-2007, 16:47 | #5 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Melbourne / Australia Age: 47
Member: 177834 Status: Offline Thanks Meter: 1,801 | Quote:
doesn't need a full flash just flash the eeprom ( download from support area ) then rebuild imei tested by me BR | |
04-23-2007, 12:37 | #7 (permalink) |
Freak Poster Join Date: Apr 2000 Location: South Wales UK Age: 54
Member: 1169 Status: Offline Thanks Meter: 59 | tried e250 eeprom and still says Bypassing MSL security... MSL security bypass failed! Possible damaged eeprom data, Try again or write new eeprom. is e250 different to e250V eeprom ? |
06-20-2007, 18:35 | #8 (permalink) |
Freak Poster Join Date: Apr 2003 Age: 55
Member: 26135 Status: Offline Thanks Meter: 18 | e250 change imei procedure download flash files and eeprom files (support area) flash phone (ex.E250_01.sfl)before eeprom and flash eeprom use rebuild imei function Reading data from box... Power ON phone... Phone detected! Loading Preloader... Preloader OK! Setting 921600 bps... Baudrate set OK! Loading second loader... 2nd boot OK! Getting Flash ID... Manufactor : SAMSUNG Chip Type : xxxxxxxxx Bypassing MSL security... MSL security bypass OK! [----- Phase-1 finished -----] now remove batt. and data cable put it again [----- Phase-2 started -----] Power ON phone... Phone detected! Setting sysol test mode... Sysol test mode ok! IMEI : xxxxxxxxxxxxxx .. Operation successful. Elapsed Time (01:09) |
06-29-2007, 07:18 | #10 (permalink) |
Freak Poster Join Date: May 2006 Location: Cape Town, South Africa
Member: 281082 Status: Offline Thanks Meter: 5 | e250 imei is easy to do, if if says eeprom damaged, just flash an eeprom file to the phone and try again, no need for full flash. as for the e250v, their eeprom files are different to the e250 and ust cant change imei on e250v, what i do is fullflash e250v with e250 flashfile then change imei, works like a bomb! |
Samsung E250 IMEI Repair not working | bbmad | UST Pro II | 2 | 12-08-2010 13:48 |
e250 IMEI repair help | my e250 | Samsung Flashers, Software, Firmware. | 2 | 02-10-2009 15:05 |
Is Samsung E250 IMEI Repair possible ? | MisterX GSMFREE | HWK | 6 | 03-22-2008 17:31 |
Samsung E250 IMEI Repair ? | MisterX GSMFREE | HWK | 2 | 03-01-2008 08:05 |
E250 imei Repair Fail.. | LoveLess | HWK | 1 | 06-13-2007 19:52 |
