03-17-2007, 17:02 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Weston-super-Mare, UK Age: 40
Member: 198717 Status: Offline Thanks Meter: 16 | The easy way to unlock a Samsung E250v 1. First of all, download a full debranded flash from the support section. I used E250_28.zip (Size: 19.28 mb) 2. Flash with the Flash and FFS. Also Mark for a format FFS! 3. FLASH THE PHONE!!! -- Have a cookie or something whilst you wait for UST to work the magic! IF you dont know how to do this then maybe you shouldnt of bought USTPro 4. Then I used a little toy (see attached) to unlock it with a COM cable. Some versions may go with UST after the flash! 5. Feel smug that you've unlocked a phone, or panic and MSN me Let me know how you get on! |
05-07-2007, 06:59 | #7 (permalink) | |
Freak Poster Join Date: Dec 2005
Member: 209289 Status: Offline Thanks Meter: 0 | thanks it is 100% solution for unlocking E250V Quote:
05-16-2007, 05:48 | #8 (permalink) | |
Crazy Poster Join Date: Oct 2006
Member: 374164 Status: Offline Thanks Meter: 1 | Quote:
07-22-2007, 03:00 | #12 (permalink) |
Insane Poster Join Date: Apr 2005 Age: 46
Member: 134928 Status: Offline Thanks Meter: 5 | Samsung E250V unlock ------------------------------- take motorola test card and start up phone, NEXT Enter: *7465625*638*00000000*00000000# NEXT ENTER: #7465625*638*00000000# AND THEN *#7465625# to check the locks... Enter: *2767*3855# (Only If first two steps is not working!!!) Repeat procedure... Tested. |
08-11-2007, 00:03 | #14 (permalink) |
Junior Member Join Date: Jan 2007
Member: 427214 Status: Offline Thanks Meter: 0 | help please Hi fellows could anyone help me with this problem, I have a samsung e256 and I formatted the ffs, the cell is damaged, I need a ffs file for this phone, I already tried flashing with e250 ffs and nothing, but flashing it with e250 fullflash + ffs the cellphone works but it doesn´t have the frequency 850Mhz, I read a fullflash + eeprom of a good e256 and flashed the cell wth this files and it doesn`t works, so I need the original ffs for e256, if someone could help me it would be great if the ust pro2 support team have this please help me, or if there is a way to read the ffs to another e256 please tell me how........ any advice or solution is welcome, thanx in advance |
08-12-2007, 00:59 | #15 (permalink) |
Member: 134928 Status: Offline Thanks Meter: 5 | Samsung E250V unlock ------------------------------- take motorola test card and start up phone, NEXT Enter: *7465625*638*00000000*00000000# NEXT ENTER: #7465625*638*00000000# AND THEN *#7465625# to check the locks... Enter: *2767*3855# (Only If first two steps is not working!!!) Repeat procedure... Tested. Finaly, use UST if this does not work, and make shure phone goes in TAT mode, other way phone will not unlock :-) |
The Easy Way to Stop Smoking: Join the Millions Who Have Become Non-Smokers Using All | IPMART | ipmart WebShop | 0 | 09-30-2009 13:34 |
solution The easy way to raise the voice of Samsung e250 100% 100 | khalid059 | Samsung Hardware Repair | 9 | 08-02-2009 20:20 |
the easy way to unlock e338 | Z-RocK | NEC | 16 | 10-24-2008 11:57 |
The most easy way to unlock HUAWAEI T201 | .::allgsmkey::. | SAGEM JTAG UNLOCKER | 2 | 09-16-2008 17:32 |
HOT NEW SERVICE - www.UnlockCodes.ie - The Easy Way to Unlock Your Phone! | GSM Solutions Ireland | Main Sales Section | 0 | 06-13-2008 17:54 |
