02-25-2008, 13:09 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: United Kingdom, ENGLAND
Member: 47774 Status: Offline Thanks Meter: 185 | G800 Unlock Problem when i flash it allways error here the log Loading flash file... Flash file loaded OK! Searching for UMTS phone... Phone detected! : COM8 Programming flash... ERR_WRITE_TIMEOUT Elapsed Time (01:48) i have try USB cable and RJ45 aswell THANKS |
03-03-2008, 14:02 | #6 (permalink) |
Member: 47774 Status: Offline Thanks Meter: 185 | SiRoYa Please can u tell me whats wrong i have buy 2 new cables RJ45-USB but allways the same problem when i try to unlock phone not found but i can flash it without any problem PS: i have use Search botton before but i can t found anything Thanks |
03-03-2008, 14:25 | #7 (permalink) |
Member: 47774 Status: Offline Thanks Meter: 185 | its ok i sorted out hey if anybody got this problem just don t power on the phone like ust soft say put the battery into the phone and Connect phone OFF wait pc detect Driver and Press unlock THanks for no any help from you Mr Siroya |
03-17-2008, 15:58 | #8 (permalink) |
No Life Poster Join Date: Apr 2002 Location: West Midlands, UK
Member: 11099 Status: Offline Thanks Meter: 5 | Hi mate got exactelly same problem as you, flashed G800 with cable supplied with phone no problem. As soon as I plug this into the device maager it picks the phone up. to unlock I aloo bought from fonefunshop USB RJ45 UniBOX, cable. However, when I use this cable to connect phone into pc, the pC does not pick up any device. I have tried what you recomened with connecting phone turned off and it not work. Can you help? FYI the cable is from GPG industries |
03-17-2008, 16:09 | #9 (permalink) |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | 1.for flashing it doesnt require usb+rj45 .. it only requires usb cable .. so u can do flashing even with orignal cable supplied with phone 2.for unlock u need rj45 + usb .. 3.when u click on Unlock .. see which port light is blinking .. put the rj45 in the same port 4. make sure u have bought Uni cable (not ufs,ns cable ) cause pinouts are different |
03-17-2008, 17:11 | #10 (permalink) |
Member: 11099 Status: Offline Thanks Meter: 5 | hello siroya, thanks for reply 1.for flashing it doesnt require usb+rj45 .. it only requires usb cable .. so u can do flashing even with orignal cable supplied with phone Yes i know this, flashing is not a problem 2.for unlock u need rj45 + usb .. - Yes this also I know 3.when u click on Unlock .. see which port light is blinking .. put the rj45 in the same port - YEs to this I am doing this 4. make sure u have bought Uni cable (not ufs,ns cable ) cause pinouts are different - Cable is correct one, rj45 + usb it is Samsung E210 / L760 / G600 Cable (RJ45+USB) For UST What am I going wrong? |
03-18-2008, 17:21 | #12 (permalink) |
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | paste here wht xactly error u getting also try change imie using same cable and post result .. |
The Following User Says Thank You to SiRoYa For This Useful Post: |
07-03-2008, 17:45 | #13 (permalink) |
Junior Member Join Date: Sep 2007
Member: 597426 Status: Offline Thanks Meter: 0 | Hey i keep getting phone not detected. The box detects it but it wont detect it. It also ***** the exclamation mark on the device manager with the cable plugged in. But with the original USB samsung cable, all that goes away for some reason. Iam using both g800 cable and e210 cable with rf45 and usb connectors. Any insight on this matter?? I also did flashing with FFS option several time. But still nothing. I uninstalled all the samsung drivers and reinstalled and still nothing. Using the latest ust pro software. Thanks~ |
07-12-2008, 16:11 | #15 (permalink) | |
Member: 47774 Status: Offline Thanks Meter: 185 | Quote:
connect phone to ust pro without turn the phone on u will see the phone start charging wait few second and press Unlock try this and post here | |
g800 unlock problem | NADEEM GONDAL | NSPRO | 6 | 06-01-2008 22:16 |
g800 unlock problem | accurate | UST Pro II | 2 | 03-05-2008 18:24 |
pantech G800 unlock problem | gsm_enggine | Infinity-Box | 2 | 08-24-2007 03:54 |
