11-29-2008, 09:38 | #1 (permalink) |
Insane Poster Join Date: Oct 2005 Location: Lelystad, Netherlands
Member: 192880 Status: Offline Thanks Meter: 35 | i200 flashing - how enter flashmode? (see pic) Hello, After downloading and extracting i200 flash package i200JCHH1, I started the ClickFlash V0.3 application. But I don't know how to connect the phone to the app. Is there a special key combination before put phone on to enter flashmode ? Br, Serkan |
The Following User Says Thank You to serjer For This Useful Post: |
11-29-2008, 16:09 | #4 (permalink) |
Member: 192880 Status: Offline Thanks Meter: 35 | Thanks Siroya, But when I do exactly what you write the Phone goes automaticly ON when I put the cable in, and no recognition in software. After a while active sync 4.5 detects the phone. What can I do more? Br, Serkan |
11-29-2008, 19:27 | #5 (permalink) | |
No Life Poster Join Date: Apr 2000 Age: 55
Member: 1246 Status: Offline Thanks Meter: 25 | Quote:
Power On with press BACK Key (Soft 2 Key). | |
11-29-2008, 21:03 | #8 (permalink) |
Member: 192880 Status: Offline Thanks Meter: 35 | Thanks both of you, But no succes. What only works is 'navigation key up' and 'power on' for format menu. With 'back key' and 'power on' the phone boots normal. To confirm I send photo with the 'back key' what I understood: Is theren not something else to do? This is a little bit strange. Br, Serkan |
The Following 3 Users Say Thank You to serjer For This Useful Post: |
11-29-2008, 21:28 | #9 (permalink) | |
U have to do as following if driver r correctly installed: 1-start software 2-Click download start button on software 3-Connect the i200 to the PC via USB while USB connecting pop up is on going. 4-Power On with press BACK Key (Soft 2 Key) to into the download mode. downloader will be started automatically | |
The Following User Says Thank You to anna For This Useful Post: |
11-29-2008, 21:41 | #10 (permalink) | |
http://www.megaupload.com/?d=LZZBEM3L | |
11-29-2008, 22:16 | #12 (permalink) |
Member: 192880 Status: Offline Thanks Meter: 35 | Anna, One more question. After nand.bin downloading become 100%, the device restart and ask for a driver again: http://www.simlock.nu/temp/i200b.jpg I don't have this driver. The device restart itself again after a while and goes to windows. But it seems something (like text and images) missing in the software. Can you help me with this driver? Br, Serkan |
11-29-2008, 22:30 | #13 (permalink) | |
Any way here is the link for working drivers tested 100% http://www.megaupload.com/?d=N7B8X4ZS | |
11-29-2008, 23:05 | #14 (permalink) |
Member: 192880 Status: Offline Thanks Meter: 35 | Link is working now. You can check it. By the way, The reason why I was flashing the phone was because the phone hangs when calling (after aprox. 20 sec. during the calling) and sending sms. You must put out the battery and restart phone. I try it again after flasing the phone, but the phone still hangs at the same time and point. Is this a hardware error then? Br, Serkan |
11-29-2008, 23:28 | #15 (permalink) | |
i200 flash | s_ahmed123 | Z3X-Team Products | 0 | 02-12-2010 08:03 |
i200 flashing - with ClickFlash V0.3.exe | serjer | UST Pro II | 0 | 11-28-2008 12:05 |
how enter g450 in test mode?? can i write flash directly to 29lv... | YeTi | Panasonic | 0 | 12-10-2003 19:48 |
