02-28-2007, 12:42 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | i607 .. phone not found I get Searching for UMTS phone... Phone not found! Elapsed Time (00:10) please advise |
02-28-2007, 13:14 | #3 (permalink) | |
Member: 43802 Status: Offline Thanks Meter: 36 | I ma using the d800/ t809 cable Quote:
I do not see an option to change port. In device manager it says UST pro II Com port 9 and UST pro II Com Port 10 Do you have to calibrate the box each time you restart the PC. does this make a difference ? | |
02-28-2007, 14:09 | #4 (permalink) |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | no u dont have to calibrate again ... it just require one time when u press direct unlock u will see lights on rx and tx insert the cable in same port side where u see leds blinking wbr siRoYa |
Looking for phone... Phone not found. | saajith | KULANKENDI Server | 2 | 12-01-2008 12:52 |
A707-phone detected phone not found! wtfo? | Vancellular | UST Pro II | 6 | 08-29-2007 16:48 |
code reader-phone not found | stonesuk | ARM9 BASED M62 / M62+ | 4 | 04-11-2004 18:59 |
Phone not found | Macko GSM | UST Pro II | 1 | 04-08-2004 15:05 |
Phone not found! Check data cable! | ACE_UK | ARM9 BASED M62 / M62+ | 3 | 02-02-2004 23:19 |
