i607 phone pin using ust 5.0- tried direct unlock, it is successful but still get message “ phone pin” …. Tried 00000000 not did not work …tried the nck code-no good. How can I set network locks; they are not highlighted? -thanks |
now when i put in a cingular sim card i get this message: "this phone can only be used with a specific sim. enter the unlock code or insert an approved sim." ust finds the phone no probem and unlocks the phone no problem wtfo? |
may be a new firmware inside ur fone .. download flash from support flash ur fone .. after flash do direct unlock |
Thank-you for your response. I do not see an option for flashing in your interface when i607 model is selected. Also now that I installed ust 5.01 today when I select the “read code” option…ust closes down……………although the direct unlock function seems to continue to go through its paces…. Quote:
me 2 have the same problem . after upgrade new i607 rom from samsung now the phone won't read the sim , and i want to downgrade the rom but couldn't find in the support for I607 |
I can read nck code why can't I read this "phone pin"? why is there no flash interface for the i607? |
just download the i607 firmware available in support page .. flasher is already inside zip |
it says its for i600.... is this the right flash for cingular usa i607? -thanks Quote:
Also have another? to add. #1 I don’t have a d800 usb cable-just the one with the rj45 end for ust- however the phone is recognized ok when hooked up with my v804ss cable using the usb half hooked directly to pc- will this cable work for this operation? Also if it helps- here is the phones info: h/w version: rev0.0 eboot version i607UCFJE -thanks |
any update on this? phone still not work |
i see you have edited your own post, however I do not see the i607 file that you uploaded Quote:
just wait 4 new i607 phone...not unlocking right now |
any update on this? need to get it working |
Still waiting on that flash file- I do not see it anywhere on the site. Here is where I am now: I have flashed the phone with AT&T’s newest firmware and unlocked the phone with direct unlock but still get message; so I tried flashing to the i600 flash on your support site- the flash was successful however now I am unable to unlock or even recognize the phone. Ust does not recognize, pc does not recognize but the phone boots up just fine what could be problem? -thanks Quote:
exactly the same problem for me... But I don't use any box. I just want flash and change the bootloader now, is it possible? Thanks! Jafangie |
