Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 05-11-2007, 20:05   #1 (permalink)
Vancellular's Avatar
Member: 479106
Thanks Meter: 44
i607 phone pin
using ust 5.0- tried direct unlock, it is successful but still get message “ phone pin” …. Tried 00000000 not did not work …tried the nck code-no good. How can I set network locks; they are not highlighted? -thanks
Old 05-12-2007, 03:21   #2 (permalink)
Member: 479106
Thanks Meter: 44
now when i put in a cingular sim card i get this message:
"this phone can only be used with a specific sim. enter the unlock code or insert an approved sim." ust finds the phone no probem and unlocks the phone no problem wtfo?
Old 05-12-2007, 07:35   #3 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
Thanks Meter: 26,411
may be a new firmware inside ur fone .. download flash from support flash ur fone .. after flash do direct unlock
Old 05-12-2007, 16:25   #4 (permalink)
Member: 479106
Thanks Meter: 44
Thank-you for your response. I do not see an option for flashing in your interface when i607 model is selected. Also now that I installed ust 5.01 today when I select the “read code” option…ust closes down……………although the direct unlock function seems to continue to go through its paces….
Old 05-12-2007, 19:25   #5 (permalink)
Member: 110856
Thanks Meter: 5
me 2 have the same problem . after upgrade new i607 rom from samsung now the phone won't read the sim , and i want to downgrade the rom but couldn't find in the support for I607
Old 05-13-2007, 01:32   #6 (permalink)
Member: 479106
Thanks Meter: 44
I can read nck code why can't I read this "phone pin"?
why is there no flash interface for the i607?
Old 05-13-2007, 07:52   #7 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
just download the i607 firmware available in support page .. flasher is already inside zip
Old 05-13-2007, 15:08   #8 (permalink)
Member: 479106
Thanks Meter: 44
it says its for i600.... is this the right flash for cingular usa i607? -thanks
Old 05-13-2007, 18:47   #9 (permalink)
Member: 479106
Thanks Meter: 44
Also have another? to add.
#1 I don’t have a d800 usb cable-just the one with the rj45 end for ust- however the phone is recognized ok when hooked up with my v804ss cable using the usb half hooked directly to pc- will this cable work for this operation? Also if it helps- here is the phones info: h/w version: rev0.0 eboot version i607UCFJE -thanks
Old 05-15-2007, 06:42   #10 (permalink)
Member: 110856
Thanks Meter: 5
any update on this? phone still not work
Old 05-15-2007, 15:10   #11 (permalink)
Member: 479106
Thanks Meter: 44
i see you have edited your own post, however I do not see the i607 file that you uploaded
Old 05-15-2007, 18:50   #12 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
just wait 4 new i607 phone...not unlocking right now
Old 05-17-2007, 22:02   #13 (permalink)
Member: 110856
Thanks Meter: 5
any update on this? need to get it working
Old 05-18-2007, 20:54   #14 (permalink)
Member: 479106
Thanks Meter: 44
Still waiting on that flash file- I do not see it anywhere on the site. Here is where I am now: I have flashed the phone with AT&T’s newest firmware and unlocked the phone with direct unlock but still get message; so I tried flashing to the i600 flash on your support site- the flash was successful however now I am unable to unlock or even recognize the phone. Ust does not recognize, pc does not recognize but the phone boots up just fine what could be problem? -thanks
Old 05-19-2007, 06:57   #15 (permalink)
Member: 84172
exactly the same problem for me... But I don't use any box.
I just want flash and change the bootloader now, is it possible?
Thanks!
Jafangie
i607 phone off mode c_ahmad79 UST Pro II 16 01-14-2012 16:34
i607 PHONE CODE??? ROUGHNECK Easy-Unlocker 0 09-12-2008 04:44
I607 Phone Pin baomobile Easy-Unlocker 5 12-20-2007 11:30
i607 .. phone not found tical UST Pro II 4 09-11-2007 13:49
Can Fighter clear a phone PIN lockout on an R290 Satellite anlog Cruiser Suite 0 05-11-2004 16:59
Page generated in 0.28510 seconds with 9 queries
