11-21-2008, 05:08 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Land of Promise
Member: 659309 Status: Offline Thanks Meter: 121 | M200 unlock problem!!using UST PRO11 action taken.. 1.ill try to direct unlock succesfully unlocked but no signal.... 2.i read some solution just to write eeprom it comes up after write eeprom have display and blinking 180000004..then hang pls need your help for this units its badly needed. here's the actual image.. |
12-01-2008, 11:23 | #8 (permalink) |
No Life Poster Join Date: May 2005 Location: Timisoara Age: 43
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 261 | @ kingskie check ffs then write this http://rapidshare.com/files/169123265/m200ffs.sff.html WITHOUT selecting ffs format |
12-05-2008, 23:21 | #9 (permalink) | |
Junior Member Join Date: Jul 2004 Age: 44
Member: 72566 Status: Offline Thanks Meter: 1 | Quote:
The Following User Says Thank You to luis fernandez For This Useful Post: |
01-21-2009, 13:52 | #12 (permalink) |
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 261 | @ luis fernandez sorry about that it works for me, now I have same error @ DATTS yes friend, this happens because I'm not a premium rapidshare user, and my file was already downloaded 10 times. try support files now, maybe it will help you |
01-21-2009, 16:32 | #13 (permalink) |
Insane Poster Join Date: Jul 2006 Location: Germany/Turkey
Member: 307514 Status: Offline Thanks Meter: 3 | When you have UST Pro you can use the Support for Flashfile, when its at time not available for you, search for the Flashfile in Forum it posted many times. When you flash your Phone set FORMAT FFS, after Flash finished you Flash this EEprom and at last you Rebuild your IMEI thats all Last edited by bittalk; 01-21-2009 at 16:38. |
can i unlock j600e using ust pro | ruvanw1979 | UST Pro II | 2 | 02-11-2010 08:35 |
SAMSUNG SGH M200 unlock problem! | aydex | UST Pro II | 32 | 07-09-2009 17:22 |
PLz Teach Me How to unlock J750 USing USt Pro 2 | readump010 | UST Pro II | 12 | 02-05-2009 15:37 |
how to unlock u880 using ust | ruvanw1979 | UST Pro II | 1 | 07-01-2008 11:48 |
E770 unlocking Problem with Ust Pro11 | sarfraz | UST Pro II | 0 | 03-26-2006 16:51 |
