04-15-2009, 20:36 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 44
Member: 88333 Status: Offline Thanks Meter: 48 | omnia i900 security code.. can please anybody give me a good help,thanks a lot in advance |
04-15-2009, 20:47 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: egypt
Member: 194207 Status: Offline Sonork: 100.1602647 Thanks Meter: 167 | u can try this (its for I8510 ) Enter test mode * # 0228 #. Press two times back then 6 and 1. Then reboot. Your settings will be reseted to factory state, and user code will be 00000000 thanks mony_valley |
The Following User Says Thank You to mony_valley For This Useful Post: |
04-15-2009, 20:50 | #3 (permalink) |
Member: 194207 Status: Offline Sonork: 100.1602647 Thanks Meter: 167 | about I900 here is the hard reset solution Hold the End and Send button lightly at the same time press Soft-Reset button with slylus and you will get hard reset menu. Just press call key and its done.. thanks mony_valley |
The Following 12 Users Say Thank You to mony_valley For This Useful Post: |
05-28-2009, 14:51 | #4 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 54
Member: 61156 Status: Offline Thanks Meter: 105 | First: Phone must be off..!!!!!! Second:call+return buttons +on ...at the same time you will see are you to format... Then press call button for ok...or return button to annulate.......... Don't forget the phone must be off with full batterie.. |
The Following 13 Users Say Thank You to belhuis2000 For This Useful Post: |
05-29-2009, 23:14 | #5 (permalink) |
No Life Poster Join Date: Aug 2008 Location: PAKISTAN
Member: 833620 Status: Offline Sonork: 100.1586892 Thanks Meter: 259 | about I900 here is the hard reset solution Hold the End and Send button lightly at the same time press Soft-Reset button with slylus and you will get hard reset menu. Just press call key and its done.. |
The Following 2 Users Say Thank You to AYAZ42 For This Useful Post: |
06-06-2009, 16:23 | #6 (permalink) | |
Freak Poster Join Date: Mar 2004 Age: 44
Member: 59489 Status: Offline Thanks Meter: 55 | Quote:
Best regards. | |
06-06-2009, 16:36 | #7 (permalink) | ||||||
Cheater -Don't Deal with him- Join Date: Sep 2006 Age: 42
Member: 354557 Status: Offline Thanks Meter: 595 | Quote:
You can select this function under Main menu -> Settings -> System -> Hard Reset or Press and hold the send and end button then use the stylus to reset Samsung i900 Omnia problem solve BR JamalMustafa | ||||||
The Following 5 Users Say Thank You to ...:::JamalMustafa:::... For This Useful Post: |
11-28-2009, 09:03 | #8 (permalink) |
Registered User Join Date: Sep 2007 Location: RO, Bucuresti
Member: 595504 Status: Offline Sonork: 100.1580419 Thanks Meter: 249 | If the Hard Reset not working u have to have 70% of bateri charge if is smalest hard reset is not begining. |
The Following User Says Thank You to ServiceTEL For This Useful Post: |
12-05-2009, 08:52 | #10 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 50
Member: 128313 Status: Offline Thanks Meter: 17 | Samsung i900 Omnia Hard Reset press call and call end keys (press at end of keys) and power on that's it. |
The Following User Says Thank You to ganesh_n For This Useful Post: |
05-18-2010, 19:45 | #13 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Good afternoon!! Friends do not understand why I can not do the procedures mentioned by you does not succeed in removing the security code of i900 Could help me |
06-02-2010, 14:03 | #14 (permalink) |
Freak Poster Join Date: Apr 2007 Location: senegal
Member: 496384 Status: Offline Thanks Meter: 23 | I900 unlock security done Searching USB (SAMSUNG Diagnostic Port) > DETECTED! Reading data from phone... SW Version : i900XHHH3_HJ1/AFHH3_HJ1 CPU : M6281A-KLRZ-4.0.95601S9) IMEI : 352819028880828 MSL Address : R4WQB67285 Analyzing security area... Calculate OK : 00007F16 Unlocking phone... ALGO Type : NEW_ALGORITHM NCK set to : 00000000 PLEASE RESTART PHONE!!! Operation successful. Elapsed Time (01:09) |
06-03-2010, 15:13 | #15 (permalink) |
Member: 88333 Status: Offline Thanks Meter: 48 | with the phone on,i push call and end button and then i hit the reset button but the phone just always restarts normally,i never get the hard reset menu,what am i doing wrong? thanks a lot in advance P.S: when i hit the reset button i have to release the call and the end button or i have to keep them pressed? thanks again |
i900 omnia security code locked | newline | Z3X-Team Products | 1 | 09-13-2009 05:19 |
Microbox UPDATE Samsung FREE FOR ALL .Omnia I900 & I900v Code Reader Added | samigsm78 | Service Products News & Updates | 0 | 07-03-2009 22:58 |
omnia i900 user code | google_uk | NSPRO | 14 | 05-24-2009 15:14 |
