01-17-2006, 15:36 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Denmark Age: 45
Member: 4205 Status: Offline Thanks Meter: 9 | Problems with E700 cable - short circuit/BSOD! If I move the connector a little, the cable and the power LED on the UST Pro II flashes - and ends with a BSOD. I don't have problems with other cables. What's up? I've tried with A800 and X640. |
01-17-2006, 22:08 | #3 (permalink) |
Member: 4205 Status: Offline Thanks Meter: 9 | I bought the box from Multi-COM a few days ago - and cables was supplied with the box. Shouldn't they be OK? I've tried to use my cable from my N-box, but I think pinouts are different, right? The cable doesn't work (but doesn't give short circuit/BSOD either). |
01-17-2006, 22:16 | #4 (permalink) |
No Life Poster Join Date: May 2004 Location: the past, which is your future Age: 45
Member: 65216 Status: Offline Thanks Meter: 23 | im having the same problem. i tried to read e335 flash memory and soft closes, windows play a "disconnect device" sound. this happens when i plug any phone to box. later i tried to unlock a r225 just for testing and it did same thing. but if i plug cable after clicking on "unlock" soft unlocks phone and works fine. this is thing to improve. regards, gsmuy |
01-17-2006, 22:58 | #6 (permalink) |
Banned Join Date: Nov 2001 Location: IRAN Age: 38
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | Cable seems to be ok. Try remove battery from your phone, (try your X640 first) start desired operation, and when it ask you to power on phone, connect phone to cable (and if not detected press power button). see what will happen |
01-17-2006, 23:22 | #7 (permalink) |
Member: 4205 Status: Offline Thanks Meter: 9 | I now have problems starting UST Pro II - again, but I think I have maybe found the problems with the cables. Where the two resistors are soldered together (with the red wire), it touches the metal "claws", that keeps the cable in the phone. Do you understand? I don't get a flashing cable (or BSOD) when I've taken the cable apart (and removed those "claws"). |
01-18-2006, 00:36 | #11 (permalink) | |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | Quote:
but as laxxe say u have to seperate the ressistors with metal .. after tht cable will work normaly wbr Siroya | |
01-18-2006, 00:44 | #12 (permalink) |
Member: 4205 Status: Offline Thanks Meter: 9 | Seperate? Shouldn't the two resistors (and the red wire) be connected? My thought was, that it was an error, that the wire was touched the "claws". I've just tried on another PC, and this just turns off immediatly, when connecting the cable - so I think this is a serious problem (and can cause damage to something). |
01-18-2006, 13:50 | #14 (permalink) |
Member: 4205 Status: Offline Thanks Meter: 9 | I've already fixed my problem. I've put in a little piece of paper/tape between resistors and metal "claws". I think I misunderstood you, I would call it seperate the resistors from metal (but maybe I'm wrong). Problem is fixed, and that's the important part :-) |
01-18-2006, 14:40 | #15 (permalink) | |
No Life Poster Join Date: Dec 2002 Age: 47
Member: 18855 Status: Offline Thanks Meter: 1,938 | Quote:
well maybe the cable u have have problem and u have do some work on the cable anyway thank for the problem u post here so that we will know the actual problem | |
problem with e700 flashing with ns pro | badgerjum | NSPRO | 0 | 10-10-2009 16:53 |
Help req with E700 cable | bouncerdove | Samsung Hardware Repair | 0 | 02-17-2005 20:29 |
Strange problem with E700 | mr_x4you | SYSOL Platform | 6 | 02-08-2004 08:08 |
Strange problem with E700 | Debster | SYSOL Platform | 0 | 12-19-2003 03:35 |
problem with e700 | Bomber | SYSOL Platform | 1 | 11-27-2003 12:16 |
