Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 09-27-2009, 15:45   #1 (permalink)
Member: 211488
Thanks Meter: 14
S5600 successfully unlocked by ust 100%
S5600 SUCCESSFULLY UNLOCKED BY UST
FLASH PHONE WITH THIS FILE BY MULTILOADER
http://www.4shared.com/file/11910534...files.html?s=1
LOG FILE
Searching for UMTS phone...
Searching for phone...
Phone has been detected!
Reading data from phone...
Calculating SP Data, Please WAIT...
Calculate OK!
Current lock status : ON (208-10)
Unlocking phone...
Operation successful.
Elapsed Time (00:28)
THNS UST TEAM
B/R
The Following 2 Users Say Thank You to shetos17 For This Useful Post:
Old 09-27-2009, 18:00   #2 (permalink)
Member: 645663
Thanks Meter: 10
Thanks UST Team..... without activation
Old 10-01-2009, 13:48   #3 (permalink)
Member: 1086080
Thanks Meter: 12
My friend, just flash this document do?? Thank you
Old 10-10-2009, 13:56   #4 (permalink)
Member: 958886
hji sir can you tell which cable i use for 5600v
and where i put in box or in computer
Old 10-10-2009, 20:29   #5 (permalink)
Member: 2779
Thanks Meter: 5
flash
hi,
i've flashed ,but same :-(
no network
Old 10-10-2009, 21:07   #6 (permalink)
sameenshah123's Avatar
Member: 619308
Sonork: 100.1591829
Thanks Meter: 243
Originally Posted by fido View Post
hi,
no network
after unlocking u have to flash with any other firmware and u will get network and unlock phone.
Old 10-11-2009, 00:01   #7 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
Thanks Meter: 26,411
use orignal usb cable which comes with phone
Old 10-12-2009, 19:44   #8 (permalink)
Member: 2779
Thanks Meter: 5
hi,
So i tried a lots of flash files,but same.
but can you tell me how can i do it ?
thank you.
fido
Old 10-13-2009, 06:46   #9 (permalink)
sakabeloha's Avatar
Member: 32403
Thanks Meter: 139
use version 9.9.52 bro!micro usb cable original or nokia n qualcomm drivers.just read code and wait 1 min.tested
Old 10-13-2009, 18:06   #10 (permalink)
Member: 2779
Thanks Meter: 5
Hi,
Thanks for your help.
I did it ,but i have a slow computer ,and the process takes more than 5 minutes...
so i've read the codes,and after i've flashed and now working :-)
cheers
fido
Old 10-20-2009, 14:46   #11 (permalink)
Member: 685001
Thanks Meter: 18
Old 10-21-2009, 03:15   #12 (permalink)
Member: 210672
Sonork: 1586124
Thanks Meter: 36
S5600 Unlocked, but "call fail"
UST can unlock s5600 latinamerican but, after that:
ĦĦĦĦĦ Can´t make a call!!! Still with network prob..
Testing with flash.
Ideas are welcome..
Good Luck
Old 10-21-2009, 03:21   #13 (permalink)
kungpaoski's Avatar
Member: 329609
Thanks Meter: 245
Just to make things clear flash unit first then unlock ??? right....
b.r.
707sc II 2008-3 successfully unlock by ust pro shawgsm UST Pro II 157 05-08-2009 22:45
>>> i520v Successfully Unlocked by UST Pro2 <<< nasirahmed UST Pro II 0 01-01-2009 12:49
.::::m200 successfully unlocked by ust pro:::::. SAMEER TAHIR UST Pro II 2 11-24-2008 16:22
A701 Telstra Successfully Unlocked by UST-Pro v 5.60 gsmtime UST Pro II 0 10-01-2007 12:29
Page generated in 0.20304 seconds with 9 queries
