10-29-2003, 15:31 | #1 (permalink) |
Banned Join Date: Nov 2001 Location: IRAN Age: 38
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | !!! UST PRO v3.05 !!! REPAIR C100 NO SIGNAL & MORE !!! What`s new : -C10x auto eeprom calibration/repair function added. -C10x eeprom calibration BACKUP/RESTORE function added. Now you can: -Repair C10x no signal. -Repair "Paused by Temperature" while charging C10x. -Repair Signal/Network faults. Notice: * Use A300 unlock cable for c10x calibration functions. * ALWAYS make backup of eeprom calibration data before doing anything with calibration data. WARNING : DO NOT TRY TO SPY/HACK UST PRO !!! IT WILL AUTOMATICALLY DESTROY YOUR DONGLE FOR EVER !!! AND WE WILL NOT FIX IT AGAIN !!! Download : www.ust-online.com WBR UST Support Team Vahid Shahabi Last edited by VsH-GsM; 10-29-2003 at 17:21. |
10-29-2003, 19:15 | #4 (permalink) |
No Life Poster Join Date: Dec 2002 Age: 47
Member: 18855 Status: Offline Thanks Meter: 1,938 | Please make a update for repair system failurecontact provider with your software..please!!!! i have problem on T100/T108, T500/T508 , N620/N628 haveng this problem and comfirm definetil software problem.. i cannot repair with your software btw i need to remove the eprom and use with laptools to repair the problem. i need to copy from the works phone bin and write it to the contact provider phone.. please!!!!!!! |
10-29-2003, 19:51 | #5 (permalink) |
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | My soft can 100% repair "system failure" on ALL sw cases. Your problems are all HW which can not be fixed, and problem can be: -Around eeprom ic, that`s why when you desolder eeprom chip & solder again, all will be ok.. -Around connectors.. |
10-30-2003, 11:47 | #6 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | Quote:
clean it and the software will work 101% WBR Syed | |
11-04-2003, 12:37 | #7 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | i try solution for c100 dosen't work always i try with c100 backup (given by vsh-gsm - thanks) the same problem... is there any other solution thanks for replying |
Ust pro 2, E250 after unlock No network & after eeprom No Speaker! | Wais777 | UST Pro II | 7 | 04-09-2008 23:55 |
ust pro 5.05 uk 429 Run time error | sung | UST Pro II | 2 | 11-18-2004 22:37 |
UST Pro v4.05 Released !!! | VsH-GsM | UST Pro II | 5 | 01-22-2004 15:08 |
!!! UST Pro v3.05 *** Flash E700 E100 !!! | VsH-GsM | Main Sales Section | 0 | 11-01-2003 16:11 |
UST Pro v3.01_SE + More Updates... | VsH-GsM | UST Pro II | 2 | 10-28-2003 20:13 |
