Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Martech Products > Martech CLIP / Box / Key
Old 03-04-2006, 12:34   #1 (permalink)
Member: 3811
Thanks Meter: 24
ax72 unlocking problem
hi there have been trying to unlock a Ax72 test points ok but all i get is error 00.13 and time out code 25 any ideas have used external power ( i think the test point shown for the black probe is incorrect as the one to right shows correct infact have tried the next test point to the right that shows correct as well ??) any ideas have only had Martech for about a week unlocked sl65 like a dream very good tool many thanks..................
Old 03-05-2006, 00:12   #2 (permalink)
Member: 3811
Thanks Meter: 24
problem now sorted some ax72 need a differant TP for prob A please look at the advice by @Levien and @Chris02 on Martech forum 100 % good service
Old 04-04-2006, 12:41   #3 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
hello
same error error 00.13 i have unlock my ax72 with martech connect tp ok
all is ok but get error error 00.13 what i can do
help...me any idea??????????
br
Old 04-04-2006, 14:32   #4 (permalink)
alfamobilTEAM's Avatar
Member: 22553
Thanks Meter: 7
Try this:
Select AX75 as phone type, set "Don't check phone Type", use AX75 TP and use "claculate codes"
Don't make "direct unlock"!
Regards!
Old 04-04-2006, 18:15   #5 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
Originally Posted by Gsm Lab
hello
br
try with an old martech version
br
zinoubinabil
Old 04-17-2006, 12:46   #6 (permalink)
msa
Member: 17424
Thanks Meter: 15
Originally Posted by alfamobilTEAM
Try this:
Regards!
Hi tried selecting AX75 and calculate codes but it comes with error 0013. The test points are different on AX72.
When I select AX72 with TP adaptor V2,3 it shows Red 'connected' but it does not show Black as connected. Could it be the Black test point is incorrect?.
I have tried all defferent version from V112 to V116 ut still same problem
br
msa
Old 04-17-2006, 13:34   #7 (permalink)
dominik's Avatar
Member: 5389
Tryed with 4 diferent PC and with old martech versions untill last one and all boot versions and test point versions but no chance????
WBR
Old 04-17-2006, 15:08   #8 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
yes same problem in my ax72??????
Old 04-17-2006, 16:22   #9 (permalink)
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
to day i unlock an ax72 with latest version 11.6
without problem (direct unlock)
Old 04-17-2006, 19:10   #10 (permalink)
msa
Member: 17424
Thanks Meter: 15
Hi
I tired for over an hour but could not unlock mine. It just would not detect 'Black' test point. I know my cable is fine becauce I have unlocked A62 with same cable.
Can you please confirm if you use same test point as its shown in V11.6?
Thanks
br
msa
Old 04-17-2006, 19:29   #11 (permalink)
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
hi
i use the same test point
but please try to restart yor pc or use power suplay or connect 9v to your test point adaptor
Old 04-20-2006, 15:03   #12 (permalink)
Member: 3811
Thanks Meter: 24
try this first connect test point cable to martech box 2 then connect the box with cable to main box i had the same time out problems this procedure helps...............
Old 04-21-2006, 09:32   #13 (permalink)
msa
Member: 17424
Thanks Meter: 15
Hi
I manged to unlock it by selecting 'Manul mode, Don't care TP line status'.
Just connected tp's and pressed the button on black tp cable and worked fine.
br
msa
Old 04-21-2006, 10:39   #14 (permalink)
Member: 26983
Thanks Meter: 11
Use MANUAL MODE option it Testpoint Adapter box and press UNLOCK than press switch in black connector
Old 04-21-2006, 17:46   #15 (permalink)
Member: 206034
yes don´t care about tp line status and do not use 9v on testpoint adapter
use V11.6
you might have no problems
AX72 unlock problem mobile_juice SIEM Service Tools 0 10-12-2009 15:11
Problem AX72 Unlock ???? koa DreamBox 2 07-12-2006 19:05
AX72 unlocking problem GSM RAJ E-Gold Based Phones 5 06-20-2006 08:29
Ax72 v1 problem cobraro22 E-Gold Based Phones 0 03-15-2006 18:57
Page generated in 0.19222 seconds with 9 queries
