03-04-2006, 12:34 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ENGLAND
Member: 3811 Status: Offline Thanks Meter: 24 | ax72 unlocking problem |
04-04-2006, 12:41 | #3 (permalink) |
Super Moderator Join Date: Feb 2005 Location: United Arab Emirates , Dubai Age: 38
Member: 113928 Status: Offline Sonork: 100.111866 Thanks Meter: 1,838 | hello same error error 00.13 i have unlock my ax72 with martech connect tp ok all is ok but get error error 00.13 what i can do help...me any idea?????????? br |
04-04-2006, 14:32 | #4 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Craiova(Romania) or www.alfamo Age: 45
Member: 22553 Status: Offline Thanks Meter: 7 | Try this: Select AX75 as phone type, set "Don't check phone Type", use AX75 TP and use "claculate codes" Don't make "direct unlock"! Regards! |
04-04-2006, 18:15 | #5 (permalink) | |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
br zinoubinabil | |
04-17-2006, 12:46 | #6 (permalink) | |
No Life Poster Join Date: Nov 2002
Member: 17424 Status: Offline Thanks Meter: 15 | Quote:
Hi tried selecting AX75 and calculate codes but it comes with error 0013. The test points are different on AX72. When I select AX72 with TP adaptor V2,3 it shows Red 'connected' but it does not show Black as connected. Could it be the Black test point is incorrect?. I have tried all defferent version from V112 to V116 ut still same problem br msa | |
04-17-2006, 19:10 | #10 (permalink) | |
I tired for over an hour but could not unlock mine. It just would not detect 'Black' test point. I know my cable is fine becauce I have unlocked A62 with same cable. Can you please confirm if you use same test point as its shown in V11.6? Thanks br msa | |
04-17-2006, 19:29 | #11 (permalink) |
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | hi i use the same test point but please try to restart yor pc or use power suplay or connect 9v to your test point adaptor |
04-20-2006, 15:03 | #12 (permalink) |
Member: 3811 Status: Offline Thanks Meter: 24 | try this first connect test point cable to martech box 2 then connect the box with cable to main box i had the same time out problems this procedure helps............... |
AX72 unlock problem | mobile_juice | SIEM Service Tools | 0 | 10-12-2009 15:11 |
Problem AX72 Unlock ???? | koa | DreamBox | 2 | 07-12-2006 19:05 |
AX72 unlocking problem | GSM RAJ | E-Gold Based Phones | 5 | 06-20-2006 08:29 |
Ax72 v1 problem | cobraro22 | E-Gold Based Phones | 0 | 03-15-2006 18:57 |
