Off Topic Zone Here all other messages... |
08-11-2011, 10:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: dil m hun
Member: 951882 Status: Online Thanks Meter: 323 | Create a bootable CD or DVD with or without floppy The information on this article will guide you step-by-step how to create a bootable CD/DVD, either using a bootup floppy disk or a boot image file. You will end up having a bootable CD or DVD, with CD-ROM driver supported, that could startup your PC and bring up the command prompt. This is going to be a good starting point, then you can run other utilities such as hard drive ghost, etc.. Many current CD/DVD burning software support the bootable feature. If you already have your favorite burning software, look around to find the bootable option. For this article, I will use the steps and sample screen-shots with the burning tool called Nero. You will need a boot disk (floppy) or a bootable ISO image to start. If you don't have one, you can download an ISO image here. This boot image is Windows-98 based, which means it uses the Windows 98 bootup sequence, which should do what we need. You can also download different boot disk images from the internet. I've found bootdisk.com has a very good collection. I assume that you already have Nero installed. Also, it is highly recommended to use a rewritable disc so you can redo the process if you have to.
If you use an image file, select "Image File" then click "Browse" to browse to the image. At the "Open" Window, browse to the location where you saved the boot image and choose the image you wish to use and click "Open" (you might need to change the "Files of type" to "All Files" in order to see files with different extensions.)
At the "Burn Compilation" Window, select "Burn"! |
The Following 2 Users Say Thank You to kapilpanday For This Useful Post: |
nokia 5130c contact service any solution with mx key (ANSWERED) | sushilsoni2003 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 08-26-2011 18:03 |
urgent help with hd7 [ANSWERED - SOLVED] | pachicoo | XTC CLIP | 12 | 08-12-2011 14:10 |
universal box usb phoenix from the flash without the help is not getting rid of the e | ramazan.keskin | Universalbox | 3 | 08-11-2011 01:26 |
C1-02 RM-643 NOT ABLE TO FLASH WITH MX-KEY 3.4 ver 2.1 (ANSWERED) | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 08-10-2011 11:00 |
please help nokia x3-00 RM-540 unlock by usb with credits | GSMHEART | Universalbox | 2 | 08-09-2011 10:02 |
