Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Off Topic Zone
Off Topic Zone Here all other messages...
Old 11-19-2018, 03:57   #1 (permalink)
Member: 2592600
Thanks Meter: 19
how to recover file from a dead hardrive
m hardrive fell from my hand and since then it stopped working. it contains my whole 10yrs work and all flashing file.
Any way i can recover them even though it involes buying a new hardrive and doing some experimentation.
Its a WD
Old 12-20-2018, 08:02   #2 (permalink)
Member: 2592600
Thanks Meter: 19
Any solution
Sent from my Infinix X604 using Tapatalk
Old 03-26-2024, 10:57   #3 (permalink)
Member: 3005236
Thanks Meter: 8
Were you able to recover the files?
In the same situation at the moment
Old 03-27-2024, 19:11   #4 (permalink)
Member: 2985358
I faced the problem of a dropped hard drive, so I feel you.
First of all, check your OneDrive or iCloud, depending on what you are using, Windows or Mac. Sometimes files are automatically backed up there.
As your HD was damaged physically, I still recommend contacting data recovery experts.
And one more tip. Even if you are lucky enough to recover the lost data with the software on your own, my advice is to buy a new hard drive or replace the damaged one if it’s still under the warranty, because it’s no longer a reliable backup source.
Hope it helps and good luck!
Page generated in 0.11495 seconds with 8 queries
