Off Topic Zone Here all other messages... |
03-31-2006, 18:13 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Morocco, Rabat Age: 45
Member: 12504 Status: Offline Thanks Meter: 10 | ibm thankpad hdd pass help? it is possible to extract hdd password from laptop eprom 24rf08 its ibm thankpad T30 ? hdd pass is different than supervisor pass! thank you. |
03-31-2006, 19:03 | #2 (permalink) |
Registered User Join Date: Sep 2002 Location: No Man's Land
Member: 15858 Status: Offline Thanks Meter: 10 | sorry it's not possible, try to visit this http://www.serviceforum.lx.ro/viewtopic.php?t=104 |
03-31-2006, 20:25 | #4 (permalink) | |
Member: 15858 Status: Offline Thanks Meter: 10 | Quote:
please read well hdd password is different than supervisor pass | |
04-02-2006, 20:47 | #7 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 44
Member: 6772 Status: Offline Thanks Meter: 17 | @all There is no pass in eeprom/rom.... electrohicham: it is possible to extract hdd password from laptop eprom 24rf08 its ibm thankpad T30 ? hdd pass is different than supervisor pass! thank you. Answer: NO! If you need DATA from your hdd, just contact nearlest data recovery company.. |
04-02-2006, 22:02 | #9 (permalink) |
Freak Poster Join Date: Sep 2005
Member: 176776 Status: Offline Thanks Meter: 5 | IBM thinkpad bios moves the password around the hdd each time the system reboots. This makes it impossible to get to the password. There are companies like ontrack that do data recovery and they copy the data bit by bit and rearrange it - this is a very expensive process (if used in a court of law the recovered data is not considered legal as it has been manipulated). For this to be done Ontrack has to receive written confirmation from the legal owner of the thinkpad /hdd (with a photocopy of the purchase document).A replacemnet HDD will usually costs lots less to install. FBI uses IBM laptops for this specific reason - from an IBM presales |
04-03-2006, 00:18 | #10 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Portugal.Chelas Age: 39
Member: 12966 Status: Offline Thanks Meter: 133 | 80% off the times bios pass is the same as hdd ppl dont use 2 pw only some expert electrohicham post bin ppl tell you the pass then you try |
04-03-2006, 03:52 | #11 (permalink) | |
Freak Poster Join Date: Sep 2005 Age: 37
Member: 182163 Status: Offline Thanks Meter: 1 | Quote:
Regards. | |
04-04-2006, 16:48 | #13 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Here Age: 60
Member: 16916 Status: Offline Thanks Meter: 3 | I also had Thinkpad t21 and I readed eeprom bios pass , hdd was diferent then BIOS and no way to find HDD pass. HDD pass is writen on HDD media not on eeprom inside laptop There is also some HDD password cracker but not work on it... So I get new HDD wbr Ziko |
04-05-2006, 19:24 | #14 (permalink) |
No Life Poster Join Date: Nov 2003 Location: GT
Member: 44659 Status: Offline Thanks Meter: 363 | HDD use what is call an ATA password which is stored in the service track of the HDD, sometimes you can recover the password from the computer's eeprom simply because is the same used for the computer, but if you connect the HDD in a different computer the disk will be locked in a permanent way. As far I know a locked HDD can be recover by two ways 1. Using an expensive forensic software that cant be cracked because use a special PCI adapter card to connect the HD to the computer 2. An online service (which is also expensive) able to perform the unlocking (not all firmwares are supported) Recovering locked HDDs is expensive because people don't really care for the value of the disk but the information. |
04-06-2006, 01:20 | #15 (permalink) |
No Life Poster Join Date: Jun 2003 Location: root
Member: 31049 Status: Offline Thanks Meter: 4 | ibm thankpad tempoary store hd pass, but it can be cracked too whit dictonary or brutal force. You can try whit ata erase command if you dont need data from disk It is not same whitch hdd is(ibm/hitachi,fujitsu,toshiba..) |
Nokia 9500 IP Pass. help | LeGrv1 | WD2 & APE (Symbian Phones) | 0 | 06-27-2006 01:40 |
LOGIN AND PASS help | .::GT-GSM MAN::. | FuriousGold | 4 | 05-28-2006 17:20 |
HDD probleme help plz? | electrohicham | Off Topic Zone | 4 | 06-15-2004 18:52 |
check this out i am trying to crack the .zip pass help me | Gsmhq | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-18-2001 12:38 |
