11-15-2006, 23:25 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Poland - Czestochowa Age: 43
Member: 115900 Status: Offline Thanks Meter: 4 | Can`t unlock by tespoint... All new models like ax72 cx65 c65 c75 goes exelent whats wrong? Happy Dreambox User |
11-16-2006, 11:27 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: dreambox
Member: 241271 Status: Offline Thanks Meter: 30 | Hi, Best_Gsm. Please check your testpoint cable. There must be a capacitor. The information about modification of S-Gold TP cable to S-Gold/E-Gold TP cable you can find here - http://dreambox.hk/support.html. |
01-29-2007, 10:56 | #3 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 42
Member: 77706 Status: Offline Thanks Meter: 26 | hi same problem here i cannot use tp method, because it does not connect always tp picture, but no reesult i measured tp cable, it's all good, i tried with and without capacitor, and many models, but no luck any ideas ? br, |
02-04-2007, 14:37 | #8 (permalink) | |
Member: 241271 Status: Offline Thanks Meter: 30 | Quote:
Please, post here an information from log window of DBSS, which is in the moment, when you are trying to connect TP. We need to know full information about your problem, because we can not help you if you just say that TP doesn't work. | |
02-06-2007, 11:51 | #9 (permalink) | |
Member: 77706 Status: Offline Thanks Meter: 26 | Quote:
here is the log, as requested thank you | |
02-06-2007, 20:50 | #11 (permalink) |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | I tested on few C60 and I fond that TP metod wort with AMD flash IC but not work with INTEL IC pleasse try yourself and you will be know what I tell. bye |
02-06-2007, 21:10 | #12 (permalink) | |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 416 | Quote:
I had checked the tp cable,all ok but I have this problem when trying to unlock some phones.Must be a bug or something,with some phones it's working other times I'm losing my time,I have to cut | |
02-06-2007, 21:18 | #13 (permalink) | |
on that particular phone (a70) i've selected by mistake tespoint mode, after i cut it ....so ...i dont think this is relevant.. anyway this is how is happening all is ok till i get the message connect tp, the tp picture pops up, and in the background, is saying 'working'.but, nohing else happens.if i hit abort, i get 'u may now disconnect testpoint', but not before, so anyway, after that it imediatelly says aborted by user(or something similar).the point is that the program acts as if i dont connect the tp at all i tryed to work a phone, using cuttrack mode and tp cable for power, and i got a mesage saying that is recommended to use battery this way, so i figured that the service cable(the one with the tp) is propery connected(or part of it).then, i measured each wire of the tp cable, and seems all good, but i dont have the schematics so i really dont know if the pinouts are correct.ok. today i tried a different thing: i flashed a s65 using tp mode, but instead of usingh the tp adaptor, when the picture appeared, i connected the tp to gnd.this way all worked well....so my guess is : the tp adaptes has wrong pinout, or the rj 45 service connector is faulty (in this cases, wont be a problem fixing it, if u can send me correct pinout), but if this 2 are ok, that leaves me with a faulty box and that is not quite good, considering the fact that my reseller does not stryke me as a very serious person(i could tell u the reasons too,if u really want but over pm ) so...pls send me pinout for the tp cable if possible, and ill let u know if i can make it work thank you for your time br | |
02-07-2007, 15:03 | #15 (permalink) | ||
Unlock for Motorola phones which you can not unlock by codes... | Denis | Main Sales Section | 0 | 10-24-2009 15:31 |
Unlock for Motorola phones which you can not unlock by codes... | Denis | Main Sales Section | 0 | 10-11-2009 18:42 |
can anybody confirm if z105 can be unlock by choosing x430 in ust | ashvin | QUALCOMM Models (3G) | 2 | 08-06-2005 20:55 |
can anybody confirm if z105 can be unlock by choosing x430 in ust | ashvin | QUALCOMM Models (3G) | 2 | 08-06-2005 15:36 |
9210 Can be unlocked by Neelix1 - so buy a cable!! | logosunlimited | Main Sales Section | 2 | 05-15-2002 20:39 |
