07-11-2006, 13:28 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: Riga , Latvia Age: 43
Member: 66399 Status: Offline Thanks Meter: 42 | CX70 amd after "unlock" beep i have some problem: cx70 ...after unlock beep.. the story is verry long. in short words when first try to unlock this phone with DBSS v1.17 or v1.18 ,dbss crashes at 99% and phone is dead... ... then i decided to change flash ic from working "beef" , after this phone works fine but got locks. so , need to unlock- with DBSS v1.23 i got dead phone again... Here is log [11/07/2006 14:32:18] --- Unlocking------------------------------------------------------------------ [11/07/2006 14:32:21] User selected phone CX70 using Firmware Bug (Manual) boot mode [11/07/2006 14:32:22] Warning : Please, connect the phone (Phone must be ON)!!! [11/07/2006 14:32:35] Warning : Please, start SReader application!!! [11/07/2006 14:32:35] Location : Games\SReader [11/07/2006 14:33:06] Working / [11/07/2006 14:33:06] Error : Failed. [11/07/2006 14:33:06] there when activating sreader dbss gives error, trying again... [11/07/2006 14:33:36] --- Unlocking------------------------------------------------------------------ [11/07/2006 14:33:36] User selected phone CX70 using Firmware Bug (Manual) boot mode [11/07/2006 14:33:36] Warning : Please, connect the phone (Phone must be ON)!!! [11/07/2006 14:33:50] Warning : Please, start SReader application!!! [11/07/2006 14:33:50] Location : Games\SReader [11/07/2006 14:36:24] [11/07/2006 14:36:24] Power On the phone ... OK [11/07/2006 14:36:26] Testing RAM...OK [11/07/2006 14:36:29] Flash Chip = AMD Am29BDS128H, size 16384 Kb [11/07/2006 14:36:29] Flash Chip = AMD Am29BDS128H, size 16384 Kb [11/07/2006 14:36:29] Flash IMEI = 353542-00-688779-2 [11/07/2006 14:36:29] Bootcore: SIEMENS CX70 [11/07/2006 14:36:29] Firmware: SIEMENS CX70 v43 lg3 [11/07/2006 14:36:29] Phone IMEI = 353542-00-688779-2 [11/07/2006 14:36:30] SPLock CRC = OK [11/07/2006 14:36:30] Phone Code = 3429 : FF [11/07/2006 14:52:36] Address : FE0000 (4598 cps) dbss stops at 97% and "doing something" +/- 20 minutes (...) [11/07/2006 14:52:36] Error : Erase #F8 [11/07/2006 14:52:36] Error : Write #80 [11/07/2006 14:52:36] Done. after this phone only beeps [11/07/2006 14:52:36] [11/07/2006 14:54:56] --- Unlocking------------------------------------------------------------------ [11/07/2006 14:54:56] User selected phone CX70 using Test Point boot mode [11/07/2006 14:54:56] Hint : Please use testpoint and press button if ready [11/07/2006 14:55:15] [11/07/2006 14:55:16] Power On the phone ... OK [11/07/2006 14:55:16] Hint : Now the probe might be disconnected [11/07/2006 14:55:18] Testing RAM...OK [11/07/2006 14:55:40] Error : can not switch baud-rate to 460800 [11/07/2006 14:55:40] Warning : Aborted by user. [11/07/2006 14:55:40] any sugestions????????????????? |
07-11-2006, 13:43 | #2 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | 1. Maybe phone's battery is uncharged 2. Try on other speed (921600) 3. Send ALL log files from DBSS with your forum's name and problem description to us? (Program Files->DreamBox->bin ALL .log files) |
07-11-2006, 13:53 | #3 (permalink) |
Member: 66399 Status: Offline Thanks Meter: 42 | DBSS v1.24 baudrate 23xxx [11/07/2006 15:47:48] DBSS Start 1.24 [11/07/2006 15:47:48] --- Unlocking------------------------------------------------------------------ [11/07/2006 15:47:48] User selected phone CX70 using Test Point boot mode [11/07/2006 15:47:49] Hint : Please use testpoint and press button if ready [11/07/2006 15:47:51] [11/07/2006 15:47:51] Power On the phone ... OK [11/07/2006 15:47:51] Hint : Now the probe might be disconnected [11/07/2006 15:47:54] Testing RAM...OK and hangs on 99% when pressin cancel button got this... [11/07/2006 15:50:39] Error : can not switch baud-rate to 230400 [11/07/2006 15:50:39] Warning : Aborted by user. [11/07/2006 15:50:39] OK, sending Log files |
07-11-2006, 14:54 | #7 (permalink) | |
Member: 66399 Status: Offline Thanks Meter: 42 | Quote:
[11/07/2006 16:53:16] --- Unlocking------------------------------------------------------------------ [11/07/2006 16:53:17] User selected phone CX70 using Auto boot mode [11/07/2006 16:53:17] [11/07/2006 16:53:18] Power On the phone ... OK here phone beeps [11/07/2006 16:53:23] Working - [11/07/2006 16:53:23] Error : Failed. [11/07/2006 16:53:23] and nothing... | |
07-11-2006, 15:00 | #10 (permalink) | |
07-11-2006, 15:06 | #11 (permalink) |
Member: 214480 Status: Offline Thanks Meter: 2,087 | Ok, I see.... Try to use IMEI boot mode: 1. Check IMEI boot mode (It uses the stored keys) 2. Check speed 921600 3. Click Unlock 4. Find phone's key by IMEI and click ok. |
07-11-2006, 15:16 | #12 (permalink) | |
Ahaa have some progress... i eeful corrupted... maybe flash with full? | |
07-11-2006, 15:44 | #14 (permalink) |
Member: 66399 Status: Offline Thanks Meter: 42 | Argh... [11/07/2006 17:15:02] DBSS Start 1.24 [11/07/2006 17:15:02] --- Unlocking------------------------------------------------------------------ [11/07/2006 17:15:03] User selected phone CX70 using IMEI boot mode [11/07/2006 17:15:42] [11/07/2006 17:15:42] Power On the phone ... OK [11/07/2006 17:15:44] Testing RAM...OK [11/07/2006 17:15:47] Flash Chip = AMD Am29BDS128H, size 16384 Kb [11/07/2006 17:15:47] Flash Chip = AMD Am29BDS128H, size 16384 Kb [11/07/2006 17:15:47] Flash IMEI = 353542-00-688779-2 [11/07/2006 17:15:47] Bootcore: SIEMENS CX70 [11/07/2006 17:15:47] Firmware: SIEMENS CX70 v43 lg3 [11/07/2006 17:15:47] Warning : EEFULL is corrupted [11/07/2006 17:15:47] Phone IMEI = invalid IMEI [11/07/2006 17:15:47] SPLock FAILED [11/07/2006 17:15:47] Warning : setting default lock data [11/07/2006 17:15:47] Error : Invalid IMEI [11/07/2006 17:15:47] Error : Failed. [11/07/2006 17:15:47] sounds like almoust done... ok trying to write ff... [11/07/2006 17:21:10] --- Loading Full Flash File---------------------------------------------------- [11/07/2006 17:21:10] User selected phone CX70 using IMEI boot mode [11/07/2006 17:21:48] Loading "E:\Mobile\CX70_lg3_v54_353542006962249_0629-1753.dtf"... [11/07/2006 17:21:55] Done. [11/07/2006 17:21:55] [11/07/2006 17:22:03] --- Writing Flash-------------------------------------------------------------- [11/07/2006 17:22:03] User selected phone CX70 using IMEI boot mode [11/07/2006 17:22:07] [11/07/2006 17:22:07] Power On the phone ... OK [11/07/2006 17:22:09] Testing RAM...OK [11/07/2006 17:22:12] Flash Chip = AMD Am29BDS128H, size 16384 Kb [11/07/2006 17:22:12] Flash Chip = AMD Am29BDS128H, size 16384 Kb [11/07/2006 17:22:12] Flash IMEI = 353542-00-688779-2 [11/07/2006 17:22:12] Bootcore: SIEMENS CX70 [11/07/2006 17:22:12] Firmware: SIEMENS CX70 v43 lg3 [11/07/2006 17:22:12] File name : E:\Mobile\CX70_lg3_v54_353542006962249_0629-1753.dtf [11/07/2006 17:22:15] Address : 002000 (93681 cps) [11/07/2006 17:22:15] Error : Failed. [11/07/2006 17:22:15] now i get this error at any move.... [11/07/2006 17:22:47] --- Writing Flash-------------------------------------------------------------- [11/07/2006 17:22:47] User selected phone CX70 using IMEI boot mode [11/07/2006 17:22:52] [11/07/2006 17:22:52] Power On the phone ... OK [11/07/2006 17:22:56] Testing RAM... [11/07/2006 17:22:56] Error : Failed. also hangs on power on phone, but when reconnect phone and battery (full one) Testing ram and failed... ... |
Any help please Phone restarts after "unlock" ( 2760 v 4.22) | Mounir | J.A.F. By Jafsupport.com | 4 | 03-06-2008 19:00 |
repair a70 v32 4mb AMD after full flash v14 | globogsm2 | SST-Dongle | 10 | 05-25-2006 02:45 |
programm crash on cx70 amd | frua | DreamBox | 9 | 03-22-2006 10:22 |
Help with CX70 "beeeeep" after EEPROM tools 3.15 | booreck | S-Gold Based Phones | 6 | 10-15-2005 04:38 |
Only beep beep after making call on MC920 | galoml | Infineon C16X M51 & ARM7 M52 BASED | 6 | 04-25-2002 02:36 |
