08-12-2009, 12:52 | #61 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Germany/Niederlande/Turkey
Member: 811992 Status: Offline Sonork: 100.1584257 Thanks Meter: 162 | very good updates and class team!!!! the J132 is also with test POINT or with normal cables! |
08-12-2009, 12:58 | #62 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | You can unlock any supported S1 with new security by testpoint ( With old security - direct unlock without testpoint.) |
The Following User Says Thank You to GSM Dream For This Useful Post: |
08-12-2009, 13:57 | #66 (permalink) | |
Member: 214480 Status: Offline Thanks Meter: 2,087 | Quote:
http://dreambox.hk/cellphones/Sony%20Ericsson_J132.php | |
08-12-2009, 16:16 | #67 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Nigeria, Oyo state Age: 48
Member: 180091 Status: Offline Thanks Meter: 62 | successfully build cable Successfully build cable and read info for sonyericson j132.ehre is the attached screen shot. More power to dream box and the team. Last edited by adebam; 06-27-2012 at 15:48. |
08-12-2009, 17:47 | #68 (permalink) |
Insane Poster Join Date: Sep 2006
Member: 356023 Status: Offline Thanks Meter: 3 | not unlocking k330a tp sud america error not supoorted Unlock and Repair---------------------------------------------------------- User selected phone K330 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. 3) Press "Power On" button shortly. Booting ... IMEI : 011xxxxxxxxxxxxxxx Version : R5A036 CXC : CXC1250616 Sending loader ... Hint : Now the probe might be disconnected Error : Unknown Flash [00EC 0000 0000 0000] [CFI Flash Chip Information] JEDEC ID - 02EC ( 00EC-3002 ) PRI Command Set - 0200 ( Unknown ) PRI Ext. Offset - 010A ALT Command Set - 0000 ( No Interface Specified ) ALT Ext. Offset - 0000 Minimum Vcc - 1.7 V Maximum Vcc - 2.0 V Minimum Vpp - 8.5 V Maximum Vpp - 9.5 V Typical Byte / Word Write Timeout - 64 mcs Typical Full Buffer Write Timeout - 2048 mcs Typical Block Erase Timeout - 1024 ms Typical Chip Erase Timeout - not supported Maximum Byte / Word Write Timeout - 256 mcs Maximum Full Buffer Write Timeout - 8192 mcs Maximum Block Erase Timeout - 4096 ms Maximum Chip Erase Timeout - not supported Device Size - 2000000 (HEX) byte(s) Bus Interface - 0001 ( x16-only async. ) Maximum Multi-byte Write - 400 (HEX) byte(s) Number of Erase Regions - 01 1) 0080 blocks of 040000 bytes Error : #2.00F104D0 Error : #2.003F0014 Error : #2.003D0580 Error : #2.003D0270 Error : Failed. |
08-12-2009, 21:58 | #70 (permalink) |
Insane Poster Join Date: Apr 2005 Location: china, cambodia, vietnam Age: 44
Member: 132968 Status: Offline Sonork: 100.1619307 Thanks Meter: 12 | same problem . please fix User selected phone K330 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. 3) Press "Power On" button shortly. Booting ... IMEI : 35179603198041 Version : R5A036 CXC : CXC1250616 Sending loader ... Hint : Now the probe might be disconnected Error : Unknown Flash [00EC 0000 0000 0000] [CFI Flash Chip Information] JEDEC ID - 02EC ( 00EC-3002 ) PRI Command Set - 0200 ( Unknown ) PRI Ext. Offset - 010A ALT Command Set - 0000 ( No Interface Specified ) ALT Ext. Offset - 0000 Minimum Vcc - 1.7 V Maximum Vcc - 2.0 V Minimum Vpp - 8.5 V Maximum Vpp - 9.5 V Typical Byte / Word Write Timeout - 64 mcs Typical Full Buffer Write Timeout - 2048 mcs Typical Block Erase Timeout - 1024 ms Typical Chip Erase Timeout - not supported Maximum Byte / Word Write Timeout - 256 mcs Maximum Full Buffer Write Timeout - 8192 mcs Maximum Block Erase Timeout - 4096 ms Maximum Chip Erase Timeout - not supported Device Size - 2000000 (HEX) byte(s) Bus Interface - 0001 ( x16-only async. ) Maximum Multi-byte Write - 400 (HEX) byte(s) Number of Erase Regions - 01 1) 0080 blocks of 040000 bytes Error : #2.00F104D0 Error : #2.003F0014 Error : #2.003D0580 Error : #2.003D0270 Error : Failed. |
08-13-2009, 01:13 | #71 (permalink) |
Freak Poster Join Date: Oct 2004 Location: chile Age: 45
Member: 88102 Status: Offline Thanks Meter: 4 | successfully unlocke t303 new security --- Unlock and Repair---------------------------------------------------------- User selected phone T303 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. 3) Press "Power On" button shortly. Booting ... IMEI : 35379003350429 Version : R5A038 CXC : CXC1250616 Sending loader ... Hint : Now the probe might be disconnected Unlocking ... Done. |
08-13-2009, 06:35 | #73 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iran-shushtar
Member: 592636 Status: Offline Thanks Meter: 674 | |
08-13-2009, 11:37 | #75 (permalink) |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | As Ussual Update by DreamBox Team, We Need data for GDFS and TA!! Including New Phones just like A2 Based phone and recently Update S1 Based TA Files !!! but, Thanks anyway team..... |
DBSS v3.18. Firmware v1.18. new LOCOSTO: T250, R306, Z250, Z320, new A2: W508, T707 | GSM Dream | DreamBox | 37 | 10-16-2009 11:11 |
PUT HERE TESTED LOCOSTO new security standalone unlock (no logs) | FullFlash2007 | DreamBox | 4 | 08-18-2009 05:05 |
DreamBox SonyEricsson v3.17.: LOCOSTO new security standalone unlock (no logs) | GSM Dream | Service Products News & Updates | 0 | 08-11-2009 16:31 |
DBSS v3.6, firmware v1.13 | matin-gsm | Service Products News & Updates | 0 | 07-02-2008 13:29 |
DBSS v3.1, firmware v1.12. FIRST IN THE WORLD: W200 Standalone permanent unlock | GSM Dream | DreamBox | 121 | 04-18-2008 03:47 |
