04-30-2008, 07:37 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: pakistan
Member: 141121 Status: Offline Sonork: 100.1580885 Thanks Meter: 20 | Dream box team help me 2 err. 2 set w200 unlocking problem itry many time but same err on both sets pls solve my problems err 2 -- Reading Box Info----------------------------------------------------------- Box SN : **** Firmware Version : 1.12.0 Firmware Build Info : 2757 03 March 2008 14:33:10 Hardware version : 1.2 Supported Functions : Siemens, SonyEricsson DreamBox driver version : 6.2.0.0 Testpoint Cable version 2 Data Cable version 2 Done. --- Security Bypass------------------------------------------------------------ User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A)-- Security Bypass------------------------------------------------------------ User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359707-01-832355-7 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Error : Invalid GDFS structure and/or configuration. Hint : Try to flash firmware. Error : Failed. |
04-30-2008, 09:08 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: dreambox
Member: 241271 Status: Offline Thanks Meter: 30 | Hi shahzad_786! Please, try to flash firmware to this phone. If DB2012 phone has "Invalid GDFS and/or configuration" and firmware flashing or GDFS reorganizing didn't help - nothing can be done. |
04-30-2008, 12:35 | #6 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Hello! Our solution depends on the configuration GDFS. If DB2012 phone has "Invalid GDFS and/or configuration" and firmware flashing or GDFS reorganizing didn't help - nothing can be done. |
04-30-2008, 14:02 | #8 (permalink) | ||
Member: 214480 Status: Offline Thanks Meter: 2,087 | Quote:
The Following User Says Thank You to GSM Dream For This Useful Post: |
how to C75 imei change with dream box pls help me... | HEDEF_GSM | DreamBox | 2 | 12-22-2006 19:33 |
please red box team help me | Zein Zozza | Redbox | 7 | 12-01-2006 13:04 |
Dream Box Error -- Help Me | KSM1 | DreamBox | 0 | 06-05-2006 12:18 |
