10-12-2006, 16:51 | #1 (permalink) |
Junior Member Join Date: Sep 2005 Age: 46
Member: 180652 Status: Offline Thanks Meter: 0 | Error: Can not connect to Dreambox |
10-17-2006, 14:18 | #3 (permalink) |
Member: 180652 Status: Offline Thanks Meter: 0 | I already did of everything, I made firmware updating changed of computer, I reinstalled the drivers and it didn't solve, it continues with that mistake, the leds are normal, when I connect does normal reading of the box, but when I put the cellular and I click in unlock appears the same error message the picture enclosure. |
10-25-2006, 19:12 | #5 (permalink) |
Member: 180652 Status: Offline Thanks Meter: 0 | Dbss.log [14/08/2006 16:38:05] [18/10/2006 11:18:07] [25/10/2006 14:33:41] [25/10/2006 14:33:49] DBSS Start 1.26 [25/10/2006 14:33:49] --- Updating Box Firmware------------------------------------------------------ [25/10/2006 14:34:10] Connecting to server ...OK [25/10/2006 14:34:15] Trying to get firmware ... [25/10/2006 14:34:15] Warning : Update not found. [25/10/2006 14:34:15] [25/10/2006 14:34:15] There are no new updates on server [25/10/2006 14:34:15] or your device is already up to date [25/10/2006 14:34:15] Done. [25/10/2006 14:34:15] [25/10/2006 14:34:25] --- Reading Info--------------------------------------------------------------- [25/10/2006 14:34:28] Error : can not connect to Dream Box ( XXX9 ) [25/10/2006 14:34:28] Error : Failed. [25/10/2006 14:34:28] [25/10/2006 14:37:39] [25/10/2006 14:37:46] DBSS Start 1.29.2 [25/10/2006 14:37:46] --- Updating Box Firmware------------------------------------------------------ [25/10/2006 14:37:54] Connecting to server ...OK [25/10/2006 14:37:57] Trying to get firmware ... [25/10/2006 14:37:57] Warning : Update not found. [25/10/2006 14:37:57] [25/10/2006 14:37:57] There are no new updates on server [25/10/2006 14:37:57] or your device is already up to date [25/10/2006 14:37:57] Done. [25/10/2006 14:37:57] [25/10/2006 14:38:05] --- Reading Info--------------------------------------------------------------- [25/10/2006 14:38:08] Error : can not connect to Dream Box ( XXX9 ) [25/10/2006 14:38:08] Error : Failed. [25/10/2006 14:38:08] |
ERROR: could not connect to server! (Fixed) | Sinta | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 10 | 03-09-2010 13:24 |
ERROR: could not connect to server! (Solved) | ayaz ali | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 3 | 03-02-2010 13:13 |
ERROR: could not connect to server! | sunny_luthras99 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 18 | 02-28-2010 10:28 |
ERROR: could not connect to server! | laduka | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-28-2010 08:51 |
