07-26-2008, 13:28 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | is this a hardware problem??!! [24/07/2008 19:59:42] User selected phone K800 using Test Point boot mode [24/07/2008 19:59:42] Stage 1 started [24/07/2008 19:59:42] 1) Turn OFF the phone. [24/07/2008 19:59:42] 2) Connect the phone to DreamBox cable. [24/07/2008 19:59:45] Boot Responce = 5A [24/07/2008 19:59:45] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [24/07/2008 19:59:47] NOR Flash ID = 2019 [24/07/2008 19:59:47] OTP Status = LOCKED [24/07/2008 19:59:47] OTP IMEI = 353996-01-******-* [24/07/2008 19:59:47] OTP CID = 49 [24/07/2008 19:59:47] EROM Color = 4 : RED [24/07/2008 19:59:47] EROM CID = 53 [24/07/2008 20:01:33] Hint : Now the probe might be disconnected [24/07/2008 20:01:43] Processing ... [24/07/2008 20:01:43] Stage 1 completed succesfully [24/07/2008 20:01:44] Stage 2 start [24/07/2008 20:06:16] Timeout detected [24/07/2008 20:06:16] Error : Failed. now after trying lots of times i get this info>> -- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 353996-01-******-* OTP CID = 49 Error : Failed. what could be wrong?? thanks in advance. BR Mansi |
07-26-2008, 14:52 | #2 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 44
Member: 52956 Status: Offline Thanks Meter: 49 | if you can read again with Dreambox try with se*** and if box cant read info your flash ic is tamperd................ you can use search and see other logs in my posts.... BR Gsmlover |
installation problem is this a hardware box problem or what??? | Unlockemall | UST Pro II | 13 | 10-25-2008 21:02 |
Is This A Box Problem | gerry1970 | MT-BOX | 5 | 11-12-2007 09:48 |
Does this means Hardware problem ? | shakeelajmal | Twisterflasher | 2 | 04-17-2005 13:31 |
how to know if a dead motorola is software or hardware problem?? | eureka8888 | Motorola Old Legacy (EMMI) | 0 | 05-14-2002 22:18 |
