07-11-2008, 12:25 | #1 (permalink) |
Insane Poster Join Date: Aug 2007 Age: 43
Member: 575824 Status: Offline Thanks Meter: 4 | how to repaire this problem Reading Info--------------------------------------------------------------- User selected phone EL71 using Normal boot mode Power On the phone ... OK Testing RAM ...OK Flash Chip = ST M58PR512J, size 65536 Kb Flash IMEI = FFFFFF-FF-FFFFFF-7 Phone ID = 0A288F6D Bootcore = SIEMENS EL71 Firmware = SIEMENS EL71 v6 lg3 Phone IMEI = 000000-00-000000-0 SPLock CRC = OK Phone Code = < NOT SET > : FF Done. |
07-11-2008, 13:30 | #2 (permalink) |
Member: 575824 Status: Offline Thanks Meter: 4 | nother one have like this,please some one guide me is this two phone can be repaired? Power On the phone ... OK Testing RAM ...OK Flash Chip = Intel 48F50xxM0Y0, size 65536 Kb Flash IMEI = FFFFFF-FF-FFFFFF-7 Phone ID = 8094D340 Bootcore = < NOT SET > < NOT SET > Warning : Language pack is missing, or you select wrong phone model!!! Firmware = SIEMENS EL71 v6 Warning : Firmware info different from Bootcore.!!! Phone IMEI = 099999-00-123456-1 SPLock CRC = FAILED Warning : setting default lock data Done. |
07-11-2008, 22:57 | #4 (permalink) |
Insane Poster Join Date: Jun 2008
Member: 793563 Status: Offline Thanks Meter: 8 | thanks,brother how to correct this says imei contain invelid corectors, --- Reading Info--------------------------------------------------------------- User selected phone EL71 using Normal boot mode Power On the phone ... OK Testing RAM ...OK Flash Chip = Intel 48F50xxM0Y0, size 65536 Kb Flash IMEI = FFFFFF-FF-FFFFFF-7 Phone ID = 8094D340 Bootcore = < NOT SET > < NOT SET > Warning : Language pack is missing, or you select wrong phone model!!! Firmware = SIEMENS EL71 v6 Warning : Firmware info different from Bootcore.!!! Phone IMEI = 099999-00-123456-1 SPLock CRC = FAILED Warning : setting default lock data Done. --- Loading Flash File--------------------------------------------------------- Loading "E:\3. Siemens\1. dream box\EL71\EL71_lg3_v6.fullflash.dtf"... Language : lg3 1. English (en) 2. German (de) 3. Estonia (et) 4. Latvian (lv) 5. Lithuanian (lt) 6. Polish (pl) 7. Russian (ru) 8. Turkish (tr) 9. Ukraine (uk) Done. --- Writing Flash-------------------------------------------------------------- User selected phone EL71 using Normal boot mode Power On the phone ... OK Testing RAM ...OK Flash Chip = Intel 48F50xxM0Y0, size 65536 Kb Flash IMEI = FFFFFF-FF-FFFFFF-7 Phone ID = 8094D340 Bootcore = < NOT SET > < NOT SET > Warning : Language pack is missing, or you select wrong phone model!!! Firmware = SIEMENS EL71 v6 Warning : Firmware info different from Bootcore.!!! File name : E:\3. Siemens\1. dream box\EL71\EL71_lg3_v6.fullflash.dtf Writting speed is 27267 cps Warning : Repair IMEI after FullFlash is not checked Done. --- Repareing------------------------------------------------------------------ User selected phone EL71 using Normal boot mode Power On the phone ... OK Testing RAM ...OK Flash Chip = Intel 48F50xxM0Y0, size 65536 Kb Flash IMEI = FFFFFF-FF-FFFFFF-7 Phone ID = 8094D340 Bootcore = SIEMENS EL71 Firmware = SIEMENS EL71 v6 lg3 Phone IMEI = 358941-00-009109-3 SPLock CRC = FAILED Warning : setting default lock data Setting IMEI = FFFFFF-FF-FFFFFF-7 New SKey = 00000000 New Boot Key = FBC5758F-780E7D13-768119F3-89871A97 New Boot Hash = E2334062-BA957013-E7E07394-DD217B36 Error : IMEI contains invalid characters Error : Failed. --- Repareing------------------------------------------------------------------ User selected phone EL71 using Normal boot mode Power On the phone ... OK Testing RAM ...OK Flash Chip = Intel 48F50xxM0Y0, size 65536 Kb Flash IMEI = FFFFFF-FF-FFFFFF-7 Phone ID = 8094D340 Bootcore = SIEMENS EL71 Firmware = SIEMENS EL71 v6 lg3 Phone IMEI = 358941-00-009109-3 SPLock CRC = FAILED Warning : setting default lock data Setting IMEI = FFFFFF-FF-FFFFFF-7 New SKey = 00000000 New Boot Key = FBC5758F-780E7D13-768119F3-89871A97 New Boot Hash = E2334062-BA957013-E7E07394-DD217B36 Error : IMEI contains invalid characters Error : Failed. |
How To Repair This Problem | WinD_VteC | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 16 | 03-10-2010 09:35 |
How to repair this problem? | Bruno Rafael | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 37 | 03-09-2010 05:02 |
how to repair this problem | celldotcom | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-05-2010 14:03 |
how to repair this problem | F@RUK S | MT-BOX | 5 | 05-23-2007 18:42 |
