07-30-2008, 07:37 | #1 (permalink) |
Insane Poster Join Date: Apr 2005 Location: Pilipinas ! Age: 43
Member: 137181 Status: Offline Thanks Meter: 3 | K530 dead GDFS success via TP DBSS this unit came to me by a fellow co tech dead ang GDFS problem when INFO on DBSS... after disassembling the phone here's the image for TP area here's the LOGS... Code: --- Reading Info--------------------------------------------------------------- User selected phone K530 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353500-02-452985-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Starting CS Loader GDFS Service ... Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K530 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353500-02-452985-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K530 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K530 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K530 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353500-SWENSONB-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K530 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K530 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353500-SWENSONB-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K530 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353500-SWENSONB-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K530 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353500-SWENSONB-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K530 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353500-SWENSONB-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K530 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K530 using Test Point boot mode Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353500-SWENSONB-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2380DC642590976E Finalizing ... Stage 2 completed succesfully Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K530 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353500-SWENSONB-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2380DC642590976E Reading GDFS... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. credit goes to boss bruce for the test unit. bogs for helping hand for the stubborn stage 2 TP and boss alfox for the encouragement. regards swensonb |
07-31-2008, 07:13 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: SRI LANKA
Member: 746449 Status: Offline Sonork: 100.1603972 Thanks Meter: 171 | do u have any easy test point for k530 i cant do this this test point please reply me [email protected] |
08-22-2008, 10:12 | #3 (permalink) |
Freak Poster Join Date: May 1999
Member: 52 Status: Offline Thanks Meter: 13 | Dear Sir, May I know which pin is for TP stage 2 as TP stage 1 is pin number 2. Please advice me please.... May I know once I sucessful done the TP stage one and do the TP stage 2 tomorrow? Thank you very much.. Best Regards Ian |
08-22-2008, 15:32 | #4 (permalink) |
Member: 137181 Status: Offline Thanks Meter: 3 | @Ian it depends on your IC variant mine is on PIN 15 and just a tip while on TP process stage 2 try to press ON/OFF switch while on TP process [stage 2] works for me all the time regards swensonb DBSS USER |
K510i 5 locks success via TP & DBSS | swensonb | DreamBox | 3 | 07-27-2008 13:57 |
s500 Repair gdfs Success Via Tp | supportallgsm | DreamBox | 0 | 06-10-2008 18:20 |
