02-16-2009, 18:29 | #2 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Hello! 1. Turn the phone into "Security Bypass" state (by testpoints). 2. Write fullflash/gdfs. 3. Perform "Unlock and Repair GDFS Security Blocks" operation. 4. Write main/FS/cust. pack That's all. |
The Following User Says Thank You to GSM Dream For This Useful Post: |
02-25-2009, 06:22 | #4 (permalink) | |
No Life Poster Join Date: Sep 2007
Member: 599037 Status: Offline Thanks Meter: 103 | Quote:
thanx | |
02-27-2009, 11:40 | #5 (permalink) |
Freak Poster Join Date: May 2008 Location: Indonesia
Member: 769748 Status: Offline Thanks Meter: 5 | --- Security Bypass------------------------------------------------------------ User selected phone W610 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357154-01-803999-4 OTP CID = 52 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357154-01-803999-4 OTP CID = 52 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2480227315F049C4 Finalizing ... Stage 2 completed succesfully Done. --- Loading flash file--------------------------------------------------------- Loading "E:\dari F\Dream box\Dreambox SE\__fullflash\W610_full_OTP-CID51_EROM-CID52_ST.bin"... Done. --- Write Flash---------------------------------------------------------------- User selected phone W610 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357154-01-803999-4 OTP CID = 52 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2480227315F049C4 Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Writing ... Error : Failed. how about this???? |
KP500 flashing problem, how to flash via usb? | kungpaoski | VygisToolbox | 2 | 03-06-2010 21:13 |
my501ci new flash ic, how to with log? | .:bono:. | SAGEM JTAG UNLOCKER | 3 | 02-26-2009 21:46 |
i change power ic how to get new imie with up | melgsm | Universalbox | 5 | 11-07-2008 11:54 |
7610 new SAMSUNG Flash ic ... how to flash /??? | CellM@n | Phoenix Black Box | 0 | 12-20-2005 11:33 |
v66 blnking . after flash error how to flash | magnet | Motorola P2k | 12 | 02-29-2004 09:05 |
