07-17-2008, 19:15 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: Algeria Age: 44
Member: 146736 Status: Offline Thanks Meter: 5 | K800 Cant Repair GDFS Error in Stage 2 I Cant execute Security By Passe Operation Stage 2 always failed and the tp is correct Help Please -- Reading Info--------------------------------------------------------------- User selected phone K800 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351707-01-******x OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Done. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351707-01-******x OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351707-01-******x OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351707-01-******x OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351707-01-******x OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. |
07-18-2008, 08:12 | #2 (permalink) |
Insane Poster Join Date: Jan 2004 Location: Slovakia
Member: 49999 Status: Offline Thanks Meter: 4 | .....http:///showthread.php?t=564194#8.... |
Cant repair gdfs in s500i | GuilleC_PMA | D-Unlock Suite | 2 | 05-15-2009 23:48 |
K800 test point procedure block after Stage 2 | ProfesionalGSM | DreamBox | 5 | 03-10-2009 20:01 |
K800 cant repair Gdfs ?? | ~mr_Ten$ion~ | SETool2 | 2 | 07-10-2008 02:21 |
